is there an off the shelf preamp module that works with the apple remote? - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th August 2014, 09:22 PM   #11
ElectroNick's Avatar
Well, i would do this :
- put parallel LCD on analog ports (no need for a new lcd)
- put rotary encoder on interupts (you want to use them !)
- put PGA2311 on some digital lines, same as IR and relays.
eg on Arduino :
0 = RotaryA (rotary_encoder)
1 = RotaryB (rotary_encoder)
2 = pushbutton (rotary_encoder)
3 = Selection Pin (spi)
4 = MOSI (spi)
5 = MISO (spi)
6 = Clock (spi)
7 = IR_receiver
8 = output for relay_A
9 = output for relay_B
10 = output for relay_C
11 = n.c.
12 = n.c.
13 = n.c.
14 = RS (lcd)
15 = enable display (lcd)
16 = D4 (lcd)
17 = D5 (lcd)
18 = D6 (lcd)
19 = D7 (lcd)
GND = R/W (lcd)
pins 14 to 19 are the analog ports, but you can call them also A0-A5.
I've tried the LCD on analog ports, works perfect.
I realise it's a bit difficult in the beginning, but you can built this and then go on tweaking your software like a pro (this will take some time, i know.....)
Nick
BOZ, BZLS, Aleph5 & Aleph J (P1.7 under construction)
Old 14th August 2014, 02:36 PM   #12
cjkpkg is offline cjkpkg  United States
MODS - we can close this thread - I will continue with my new thread which is more relevant to the project objective.
Old 14th August 2014, 02:45 PM   #13
Turbon is offline Turbon  Sweden
Turbon's Avatar
I have an old ARDUINO implementation of an APPLE remote in some old Wolfson Thread - Still using the DAC but without the ARDUINO
And I surely not want you to be able to clear the info you got from others that can be very useful... Well, if you wan't to Ok, go ahead - I've copied the lot
Old 29th August 2014, 01:15 AM   #14
dangus is offline dangus  Canada
Nuts and Volts published plans for a PIC board that could learn IR codes. IIRC it was designed by aade.com
I have the article, layout, and firmware somewhere. PM me if interested.
volume remote control module with PGA 2311 Jempie Analog Line Level 166 17th March 2017 07:00 AM
A remote control preamp in the works timbarnes Analog Line Level 57 11th May 2014 06:57 PM
ABBRES Remote Control Module Ronmeister Swap Meet 2 17th April 2014 02:24 AM
Remote controlled Preamp for PW120 module dyolFkniP Solid State 1 8th January 2011 09:03 PM
HiFi Premp schematics? Mlaen Solid State 9 3rd October 2004 05:00 PM
Copyright 1999-2017 diyAudio
