help with 2 pole low pass filter/attenuator
Old 13th August 2014, 09:06 AM   #21
R.I.P.
An active second order filter will be identical if you CHOOSE to have the same roll-off frequency and the same Q.
The big advantage of active filtering, is that it is easy to choose different filtering parameters.
regards Andrew T.
Old 13th August 2014, 04:00 PM   #22
DF96 is offline DF96  England
Yes, an active second-order filter (or a passive LCR filter) can have designer-chosen Q - which may be smaller or greater than that imposed by a passive CR filter.
Old 14th August 2014, 07:34 AM   #23
clm811 is offline clm811  United States
clm811's Avatar
Default Thanks, Now for the high pass...
On my Sure model AA-AB32186 board, I noticed that the 22k shunt resistor is placed before the series input coupling cap [first image]. The resistance from shown test point to ground is 76k ohms.
BTW, I've replaced the damaged 22k shunt resistor with an 18k 1/8w 1%metal film resistor, since it was the nearest value small resistor I had on hand).
In most input circuits the shunt resistor is after the series cap, making input filter frequency calculation easy[second image].
How would one determine the low frequency cutoff in this case, by using the 76k or the 18k as the input impedance?
Thanks.
p.s. I'm using a first order high pass (series cap) to be 400Hz (near the -3db point of the midrange sealed box response).
Old 14th August 2014, 10:47 AM   #24
R.I.P.
the resistance before the DC blocking cap has virtually no effect on the way the amp or the filtering operates.
When passing a signal into the amp the source is connected.
The source impedance appears in parallel to the 22k/18k and since the source impedance is usually very much smaller than 18k, the effect of the 18k is effectively nil.
The 18k is put in there to give the input terminal a reference to Signal Ground. It dissipates any leakage through the DC blocking capacitors to Signal Ground.
Generally this resistor is very high in value 100k to 2M2 is commonly seen.
Some amplifiers even omit it.
Omitting it gives problems if you mistakenly disconnect ot reconnect the interconnect cable while the amplifier is ON.
A DC voltage can build up on the input terminal and connecting the cable shorts this voltage to ground. This creates an instantaneous change in voltage at the input and results in an amplified version (an almighty "crack") appears at the output. This can damage speakers".
regards Andrew T.
Old 14th August 2014, 05:09 PM   #25
Pyramid is offline Pyramid  United States
Pyramid's Avatar
I think your cap value is off by 2 decimal places. As drawn, the 3dB point will be ~4Hz. Your cap should be .022uFd for 400Hz.
Old 15th August 2014, 04:54 AM   #26
clm811's Avatar
Perfect!
I just received my 0.022uf(22nf) MKP caps yesterday!
help with 2 pole low pass filter/attenuatorHide this!Advertise here!
Low pass filter funky2x Chip Amps 5 22nd April 2013 03:01 PM
Low pass filter? wind dance Car Audio 8 13th September 2011 02:38 PM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Low Pass filter for sub? cathode_ray Subwoofers 9 25th April 2007 05:04 PM
NO low pass filter? jmar Digital Source 7 19th January 2006 12:53 PM
