Low level interconnect (RCA) measurements
Old 8th August 2014, 01:50 PM   #11
On Hiatus
SY's Avatar
Originally Posted by Conrad Hoffman View Post
I think I mentioned that, as mica caps are the example always used for very low DF with surprisingly high DA. It's true, but that "high" DA is in comparison with better dielectrics and my guess is it isn't even on the map compared to the stuff they make cables out of, with the exception of Teflon.
If memory serves (I don't have my tables with me), the worse DA among polymers is from PVC, and it's still 5 times lower than mica. That is going off memory, though, and I'm old.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 8th August 2014, 01:51 PM   #12
BigE is offline BigE  Canada
BigE's Avatar
Hi Conrad,
Have you tried using audiodiffmaker?
Old 8th August 2014, 01:55 PM   #13
freax is offline freax
freax's Avatar
Remember, no edge here! The input signal is a 2 kHz triangle wave, not square, and the edges you see on the scope are the result of the triangle switching direction. The droop is a relatively slow thing in comparison.
I know for certain my ears are not golden and I don't know about hearing .08% of anything (there's no 24Vpp, the input is 12Vpp), so it either gets much worse at higher frequencies or I'm not looking at the math right. I may not be choosing the cutoff point of the droop correctly on the relatively fuzzy scope image.
I tend to believe that whatever changes to the signal you cannot hear are multiplied by whatever other chances you cannot hear in every other component in your system to the point where you hear a definite change from what you /should/ be hearing.
Everyone knows what a Trumpet sounds like. now put that through a hundred components and then try to make it sound the same.
https://www.youtube.com/watch?v=d70fiI2Mn_A
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 8th August 2014, 02:02 PM   #14
udok is offline udok  Austria
You are right! At the moment i saw only the scope pictures with the rectangle...
Old 8th August 2014, 02:02 PM   #15
Conrad Hoffman is offline Conrad Hoffman  United States
Originally Posted by BigE View Post
Hi Conrad,
I've fooled with that in the past and don't remember much, but it's a very good idea. This is stuff that really needs to be crosschecked using different methods.
BTW, anybody with a scope can, and should, duplicate this test. Almost all two channel scopes will let you invert one channel and then sum them (A+B mode), giving you a differential amplifier. Find a couple matched resistors, a function generator and Bob's your uncle. You won't have the gain available on my diff plug-in, but the signals here should be quite visible with normal 5 mV/div settings.
I may be barking up the wrong tree, but at least I'm barking!
Old 8th August 2014, 02:04 PM   #16
Kastor L is offline Kastor L  Europe
Kastor L's Avatar
Send a message via ICQ to Kastor L
I'm curious how Teflon will perform in your tests, will you acquire any? I could send you a piece for free.
SKY reference
Old 8th August 2014, 02:26 PM   #17
jcx is offline jcx  United States
yes, use any polymer film dielectric before Mica https://web.archive.org/web/20051226...570,28,00.html
and some rambling What's all this soakage stuff, anyhow? | Analog content from Electronic Design
Old 8th August 2014, 02:39 PM   #18
R.I.P.
Yes, the triangle to square is a bit of a handy trick. The best way to see it is to draw two triangle waves
does that mean the output is in effect a measure of the phase shift?
regards Andrew T.
Old 8th August 2014, 02:47 PM   #19
Yes, but not in the usual AC sine wave sense. Think more in terms of charging the cap with constant dV/dT (triangle) through a resistor, rather than a sine function.
Kastor- yes, I tested some Teflon aircraft coax. Fantastic stuff on the waveform, also has a dissipation factor of 0.00002, though moderately high capacitance.
Old 8th August 2014, 02:55 PM   #20
Originally Posted by jcx View Post
I have to reread Pease, but actually don't agree with never using mica. I've used it in RIAA sections with no sonic problems I could detect. Mylar is a far worse performer for distortion and I avoid it when possible.
An interesting thing about mica caps is that I've never heard of them being a problem in any AC circuit, only with slow speed stuff like integrators. Interesting that they also look good in my test. Does anybody know anything about dielectric absorption frequency ranges? Does performance in a 1 second test predict high frequency behavior? This seems like stuff we need to know to predict audio performance. Later today I'll try to run some traditional DA tests on the same cables.
Now, I think it's Rod Elliott that makes a good argument for dielectric absorption not being audible or a factor in audio. I respect him greatly and he makes a good argument, but I also think circuit locations and impedances are everything when it comes to what's important.
Low level interconnect (RCA) measurementsHide this!Advertise here!
RCA interconnect with Cat5 ? gychang Everything Else 29 8th April 2017 09:24 PM
Interconnect cables (RCA) mfspdesigns Vendor's Bazaar 2 8th May 2014 02:58 PM
RCA interconnect configuration KCC Everything Else 4 19th January 2008 12:13 AM
RCA into XLR interconnect Idea Brian Donaldson Everything Else 12 30th August 2005 04:59 PM
HOWTO: High/speaker to low-level/RCA converter ??? bbaker6212 Multi-Way 2 10th September 2002 05:04 PM
