Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
http://www.diyaudio.com/forums/analo...e-control.html
" Bass [20Hz] Drum [120Hz] Lower Voice [500Hz] Presence [2Khz] Rasp [5KHz] Air [20KHz] " ![]() |
#12 |
Sounds like you like to play DJ, why not just get some pro audio kit? Best EQ you can buy as well as various other functions. If you are playing a preamp as an instrument you'll have a blast with a DJ controller, mix console, and rack EQ. Assuming money is no object, that is.
"You lose, Rickles!" - Jim Lahey |
#13 |
I agree with benphysics, flat is usually harsh or brash or thin etc. The recording process is often a crapshoot created by a poorly educated mixer guy. Level changes bring up the issue of a "loudness comp" function, but it's got to be done right (variable). More bass should always sound better, but there's the shroeder frequency room acoustics issue that usually causes boominess, so more bass will often make that worse.
Personally I think it's laughable that high end preamps rarely have tone controls, and if they do the tone functions are meager. I prefer a 4 section Baxandall (variable slope) tone circuit myself. Any less is not enough, and any more becomes a distraction from the listening experience. I chose to design and build my own preamp just for this reason. See it at my website: Bob's Website |
#14 |
Did you haveto pump it up before each listening session?
#15 |
Actually the room was virtually maintenance free. The floor was built out of 2x10 joists sandwiched between 5/8 baltic birch plywood and all was glued together. Between joists the floor was filled with insulating materials and the upper part, the part we sit on is carpeted with a 1/2 inch underlayer of felt material. The entire floor was octogonal 16 feet diameter on the corners. It rested on 12 firestone suspension airbags (automotive type) inflated at 20# pressure. I would verify it every 3 months, but never had to readjust in 9 years I owned the home. I then moved from Quebec to British Columbia, in Canada that is. When the music would play in the neighborhood of 115 to 120 db, it was easy to hear a fly sooming around. Actually, it was even disturbing; we had to catch it and throw it out of the room.
#16 | |
#17 |
Woah...the fly was audible with music playing at 115-120 dB. I'm glad that part is over!
MiniDSP is said to be good for bass management, but not so much for main channel audio listening. Their support forum is also a mess and I will leave it at that. You might want to look into the preamp/DSP/digital crossover from DEQX. That would be worth a listen. Another would be the Accuphase DG-28 DSP that was said to be sonically invisible, and may have had a volume control for preamp duty. Stay away from the Classe crap. On the other hand, the distributor of Harbeth once said "You should never try to compensate for something a speaker can't do". In light of that, I have yet to see a perfect speaker, recording, or room all in coincidence. Last edited by kouiky; 7th August 2014 at 02:15 AM. |
#18 | |
Stay in touch, Ben |
#19 |
Hi Ben,
I like your thinking. The "loudness control" is an interesting area. To my mind far and away the best one I have seen is in an old "Journal of Audio Engineering Society" mag from the 70's. It was good, very clever and cheap to DIY. It was interesting because the designers built it with a variable "break point" for the bass reinforcement. I.e. as the volume decreased the point at which the extra bass increased moved up the frequency scale. (Or more correctly, the point at which the lower mids were depressed moved up in frequency....) From memory each channel involved only one op-amp and a handful of passive components, the final result was within plus or minus 3db of the Fletcher/Munson (if I've spelt it correctly) curves over a 50 plus db range, all controlled through one linear pot that carried no DC current. Now I can't put my hands on my copy at the moment. If you're near a Uni you might chase it up. But I can recall that it was NOT an item listed on the cover (sorry) which will make it harder to find but was down the back in the "Engineering briefs" section I think. If you do physical search you will need to check the index.... I'll have a look at my "archives" and see if I can get a more precise reference, date Vol. No. etc......then you can but a copy from them for a small fee even if not you're a Audio Society member. Cheers, Jonathan
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse. |
#20 |
Hi Ben found the complete details for the reference above;
"Practical Loudness:An active circuit design approach." Arthur L Newcomb and Richard N. Young. JAES Jan/Feb 1976 Volume 24 No.1. Down the back in "Project Notes?Engineering Briefs" Cheers, Jonathan
Thread | Thread Starter | Forum | Replies | Last Post |
Is there any audiophile quality of latin and country music cd or samples ? | gaetan8888 | Music | 9 | 5th December 2010 07:09 PM |
High quality audiophile op-amps | RichLund | Swap Meet | 2 | 27th February 2010 09:24 PM |
DIY Audiophile Series: How to Make Your Own Audiophile Quality 300B Valve Amp (4DVD) | scav | Swap Meet | 1 | 12th October 2009 03:14 PM |
Audiophile Quality 6x9s | M50SNIPER | Car Audio | 14 | 21st January 2009 12:38 AM |
Audiophile quality multi room? | MMeche | Digital Source | 2 | 24th March 2008 12:20 AM |
New To Site? | Need Help? |
