Sowter type 3232 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 2nd August 2014, 09:49 AM   #1
merlin el mago's Avatar
Question Sowter type 3232
I want to connect Sowter type 3232 as unbalanced to balanced, I guess unbalanced inputs are: White 4 & Pink 6 and balanced outputs are: Green 1, Grey 2 & Brown 3, Black 5 to chassis earth?
Specs: Sowter Type 3232
Old 2nd August 2014, 10:59 AM   #2
What exactly are you planning to do there? This is a 10k/10k and would probably not be too happy driving larger amounts of cable capacitance. It is best suited for an input as a balanced to unbalanced xfmr. You could wire it up as a 2:1 (10k/2k5) but then you'd be losing 6 dB of output level.
If you just need a balanced output without the need for transformer isolation, see Jensen appnote AN003 on how to do this most easily. (Actually their other stuff is well worth a read, too.) This yields a properly balanced output but does not give distortion cancellation in a typical active balanced input stage (which occurs with symmetrical driving, as a large portion of common-mode distortion cancels out or does not occur in the first place).
Old 3rd August 2014, 05:06 PM   #3
I want to use the Sowter, any advice how have I to connect?
Old 5th August 2014, 10:21 AM   #4
Today I received Brian (Sowter) support:
"Connect Green to unbalanced hot. Brown to unbalanced cold. Leave Grey unconnected. Connect White and Pink to balanced hot and cold (Pins 2 and 3 on XLR). Connect Black to unbalanced cold (Brown)"
Sowter SA01 - anyone used it ? Bigun Tubes / Valves 1 4th May 2012 01:08 AM
Sowter 3607 Doz Tubes / Valves 2 3rd May 2011 07:55 AM
Sowter Service jackinnj Analogue Source 0 14th September 2010 12:00 AM
Sowter 9055 wildmonkeysects Swap Meet 4 1st May 2008 02:30 AM
Sowter 5113 croccodillo Tubes / Valves 0 28th June 2007 12:40 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
