Balanced to unbalanced. - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st July 2014, 01:16 PM   #1
back is offline back  Greece
Default Balanced to unbalanced.
Hi there.
is there a way to take advantage of the balanced negative output so i can make a single ended output of double double voltage?
l think transformers would do it but something cheaper would be nice since i have 8 outputs to convert.
Old 22nd July 2014, 09:29 AM   #2
google reports
Balanced To Unbalanced Audio Converter
5 Feb 2009
Line input transformer for unbalanced to balanced ...
22 Dec 2007
unbalanced to balanced converter
20 Sep 2003
Wanted->Discrete balanced to unbalanced CMR converter
20 Sep 2003
More results from www.diyaudio.com
regards Andrew T.
Old 22nd July 2014, 09:50 AM   #3
Did it Himself
richie00boy's Avatar
The short answer is no, unless the balanced output is the quasi-floating type, which is not very popular as it requires manual trimming at production.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more.
Old 23rd July 2014, 03:42 PM   #4
thanks for the replies i guess i must consider transformers
Balanced To Unbalanced Help paul79 Construction Tips 40 18th April 2014 01:51 AM
unbalanced/balanced to balanced converter kevin gilmore Analog Line Level 4 26th February 2013 08:31 PM
Unbalanced to Balanced mcash257 Parts 3 14th October 2004 12:03 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
