How to change active xover frecuencies
Old 16th July 2014, 03:33 PM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default How to change active xover frecuencies
How to change active xover frecuencies of Reckhorm F1 active xover, now the high cut adjustable 30-100Hz, low cut adjustable 50-100Hz.
I want to filter tweeter Seas Millenium TCF002 with a low cut filter 1.000Hz and advice for high cut filter for SS18W8545-00
Attached pics with schematic & manual.
All help will welcome.
TIA
Felipe
File Type: jpg Reckhorn active xover F1 Higher Output Voltage MOD.jpg (466.2 KB, 89 views)
File Type: pdf RECKHORM F1 ACTIVE XOVER manual_web.pdf (959.0 KB, 18 views)
Old 16th July 2014, 03:44 PM   #2
The highlighted resistors are for gain setting.
But these gains are monstrously high @ +9.8dB and +20dB !!!!
The filters are the 8 opamps to the right.
All 8 are unity gain Sallen and Key.
regards Andrew T.
Old 16th July 2014, 03:46 PM   #3
Thanks Andrew, how can change the frecuencies? yes the attached schematic is to change the xo for high gain.
Old 16th July 2014, 03:57 PM   #4
Technical data:
power supply 230 volts / 50 Hz or 110 volts / 60 Hz
input sensitivity 0.1 - 10 volts / 10 k ohms
satellite stereo signal output + 3 dB / 47 k ohms
satellite frequency response 50 - 40000 Hz -1 dB
satellite high pass, stereo, variabel 50 - 150 Hz / 24 dB
satellite total distortions 0.001 %
subwoofer 2 x mono signal outputs max. 10 volts / 47 k ohms
subwoofer frequency response 15 - 150 Hz -1 dB
subwoofer 2 x mono low pass variabel 40 - 150 Hz / 24 dB
subwoofer total distortions 0.001 %
signal - noise ratio subwoofer and satellites over 95 dB
power consumption with signal input max. 3 watts
power consumtion without signal max. 2.5 watts
width x height x depth (mm) 155 x 48 x 130
weight 0.7 kg
Old 16th July 2014, 04:10 PM   #5
read up on
regards Andrew T.
Old 16th July 2014, 04:29 PM   #6
Like the linkSallen-Key Low-Pass Filter?
Old 16th July 2014, 04:48 PM   #7
woody is online now woody
Active Filters
But it doesn't seem to be all that much like the ones described in
that article but I could be wrong.
Old 16th July 2014, 07:03 PM   #8
I got this schematic for Sallen-Key Butterworth High Pass Filter
With the calculator online for 1KHz I got:
Ca 11.25nF
Cb 11.25nF
Ra 20K
Rb 10K
Are these values OK?
The schematic isn't the same like the reckhorn uses....
Old 17th July 2014, 08:45 AM   #9
C1 = Ca
R19 = Ra
etc.
regards Andrew T.
Old 17th July 2014, 09:07 AM   #10
How to change active xover frecuenciesHide this!Advertise here!
Active xover help. awkwardbydesign Analog Line Level 18 18th June 2012 05:08 PM
Series-wiring drivers instead of parallel, how does the Xover change? Glowbug Multi-Way 1 16th January 2007 04:46 AM
Need to change passive xover frequency georgehifi Multi-Way 17 6th October 2006 12:21 PM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
active xover 5th element Solid State 0 9th March 2003 07:19 PM
Copyright ©1999-2017 diyAudio
