Shine7 12au7 preamp builds? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th June 2014, 09:58 AM   #1
ChiDave is offline ChiDave  United States
Default Shine7 12au7 preamp builds?
Has anyone built this preamp? I'm looking for a low (or variable) gain tube amp.
It would be great if it were easier to find established projects here more easily than sifting through all of the threads. Am I missing anything?
thanks
Old 1st July 2014, 01:27 PM   #2
Ok. Anyone care to take a look at this design and offer an opinion? I'm going to build this unless someone can point me to a project here with a complete schematic that they're confident is significantly better. The one problem with the Shine7 project is it doesn't include the PSU design.
DIY 12AU7 Tube preamp
Thanks, Dave
Old 1st July 2014, 02:07 PM   #3
DF96 is offline DF96  England
A voltage gain of 10 is not low, it is high. Most audio systems need a gain of about 1. Why do you think you need a preamp?
Old 1st July 2014, 02:21 PM   #4
I originally thought all I needed was a quality buffer and volume control since my DAC output is the max that my amp needs. I'm driving my system DAC direct right now. In a perfect world I'd build a preamp where I could select 0, low, or fairly high gain. But, I'd rather not add that complexity to this design.
The reality seems to be even very low distortion preamps with gain can alter the sound in a way that many people think is a change for the better. I assume this has a lot to do with second harmonics, but probably other, more subtle, things as well. I've stopped worrying about the science behind why things like this seem to be true. And hey, I'm building it myself, so why not give it a try?
PS: I'm using a BMC PureDac which they claim adds currnet to improve the "preamp" section's performance. I'm not qualified to delve into analyzing this. At least they say they're doing something to make it work better than simple digital volume attenuation.
PPS: Yes, I'd take a gain of 4 or 6 instead of 10. At least it's not 15 or higher.
Old 1st July 2014, 03:41 PM   #5
0.058% THD - probably mainly second order - at 2V pk-pk output may be enough to colour the sound a little. This is just 70mV RMS input, so you need to put the volume control before the preamp. Other things being equal, a 2V RMS CD player output could give you 1.6% THD. Or you may prefer this! A low distortion preamp would do much better than this.
Old 8th July 2014, 09:06 PM   #6
nigelwright7557's Avatar
Thanks, Dave
I would have added a grid stopper to first stage to kill RF.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 19th July 2014, 07:19 PM   #7
Thanks, Dave
the shine7 6922 version is much better than the 12au7 version
Old 19th July 2014, 08:12 PM   #8
Subscribe
Old 20th July 2014, 05:22 PM   #9
sorry, forgot to reply to your other question--there are two respectable 6922 preamp PSUs shown here: RJM Audio - Tube passive phono preamplifier although i'd be inclined to also go with DC for the heaters using LM317 current source for regulation. there's a useful discussion of LM317 and similar current source regulators at: LM317 / LM338 / LM350 Current Regulator Calculator and Circuits. Also, if you haven't looked at Pete Millet's stuff, it's very worthwhile IMHO. http://www.pmillett.com/
Old 22nd July 2014, 02:03 AM   #10
I'd thought of the 12au7 version because of its lower gain. I will consider the 6922 also. I have Pete's 'Low Mu' preamp bookmarked as another candidate. Thanks for the input.
12ax7 12au7 preamp Bengali Tubes / Valves 17 8th January 2012 07:46 PM
tony builds a 7N7 preamp TonyTecson Tubes / Valves 19 8th November 2011 01:22 PM
Preamp resistors calculation for http://www.shine7.com southernoise Tubes / Valves 5 18th July 2011 01:59 PM
Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT spiritm2r Tubes / Valves 1 6th March 2011 02:53 PM
Look for 12AU7 Preamp Circuit . RCA245 Tubes / Valves 2 2nd June 2006 02:02 PM
Copyright 1999-2017 diyAudio
