low pass filter for DAC output - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 1st June 2014, 02:47 PM   #1
kinku is offline kinku  United States
Default low pass filter for DAC output
I am wondering if someone can help me with a Second order low pass filer using transistor for PCM1704 DAC output. Will a passive filter work better than an active one?
Old 1st June 2014, 03:47 PM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Yes a passive filter will generally sound better than an active one as it won't be prone to IMD. Why do you want only 2nd order and what function is the transistor playing?
It doesn't have to take the form of a conspiracy, rather a consensus... James H Kunstler
Old 1st June 2014, 05:00 PM   #3
I am not sure if it need to be one with transistor ( or active) but no OPAMP based on is being considered.
There is no particular reason for selecting second order. That is what being used in other DAC models, active though.
Old 2nd June 2014, 02:40 AM   #4
abraxalito's Avatar
I'd suggest going for a higher order filter if you're going to use the PCM1704 in NOS. I use 11th order currently (5 inductors, 6 caps per channel). If you want to run OS then you can use fewer components in the filter as it doesn't need to be as steep. However I reckon NOS and a steep filter sounds best.
Old 2nd June 2014, 02:59 AM   #5
I am using it as NOS configuration, I would appreciate if you please share the filter schematics/ details. Also curious to know how you made those inductors.I guess the filter is a Bessel-Butterworth?
Old 2nd June 2014, 03:39 AM   #6
You will certainly need golden ears to hear the effect of an 11th order
supersonic filter over one that simply does the the job required on a DAC
output, which is typically 2nd order LP op-amp based I/V conversion.
Assuming NOS means no output stage and OS means output stage,
how on earth do you come up with a 11th order filter as sensible ?
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 2nd June 2014, 03:45 AM   #7
This is my DAC design, I do not want to make it too complicated. So any idea is welcome as long as it is practical and does not involve extreme measures. Sreten I have the I/V conversion taken care of from PCM datasheet. Not sure if I need a low pass filter or not after IV. A transistor based Low pass filter is the one I am looking for. Second or third order perhaps. But not sure which way to go
Old 2nd June 2014, 04:05 AM   #8
rgds, sreten.
Non oversampling (NOS) and oversampling prefilter sorry
Old 2nd June 2014, 04:17 AM   #9
Sorry on my part, that makes a lot more sense.
rgds, sreten.
Old 2nd June 2014, 04:56 AM   #10
abraxalito's Avatar
Its on my blog, here - http://www.diyaudio.com/forums/blogs...ev-filter.html
This particular filter uses bought inductors (TDK) but in previous designs I've used pot cores to fashion inductors from. No, the filter's Chebyshev to get a steep slope before the imaging components kick in. In going NOS there's not much room (frequency-wise) between the top of the audio specturm and the start of the imaging products (24.1kHz). Which is why so many DACs have historically used oversampling so the steep filter's digital, rather than analog.
low pass filter panos1 Analog Line Level 14 15th December 2013 09:10 AM
Do I really need any DC output capacitor between a DAC chip and the low pass filter ? ygg-it Digital Line Level 3 7th April 2011 12:16 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Class D output low pass filter EMI suppressor rickco Class D 4 28th October 2009 05:15 PM
Low pass filter on DAC output Tenson Parts 1 12th September 2006 02:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
