suitable power supply for dozen opamps?
Old 2nd June 2014, 02:13 PM   #21
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default 15 VOLT +/- REGULATED SUPPLY
Hello
greetings simple regulated supply used in studio series preamplifier
warm regards
andrew
"It's Better to try and fail than to never know and always wonder"
Old 2nd June 2014, 02:25 PM   #22
sorry this is correct schematic
Old 2nd June 2014, 02:26 PM   #23
ac transformer 18 0 18 2 amps use heat sink for LM317T LM337T
Old 3rd June 2014, 10:28 AM   #24
giro1991 is offline giro1991  Scotland
giro1991's Avatar
cheers moo, this was buggin my head all night ...
.. never really mastered electronics at school, failed physics because of it, passed second time round though,
I read EL transformer is more suitable for low level applications such as this over toroid...
However do I still need to take any precautionary mesures to supress humming regarding distance?
Originally I was going to incoorporate all of this into a butter dish for simplicity but it looks like I'll need something slightly bigger...
Michael Gerzon's Trifield decoder: foobar2000 plugin - free
Cheap 20bit ladder dac with 4 fs minimum phase (IIR) filter TDA1306.pdf
Old 3rd June 2014, 10:42 AM   #25
Mooly's Avatar
Radiated hum from the tranny shouldn't be an issue unless you wrap wires round or against it. Just keep a few inches space between it and the PCB/signal wiring and it will fine.
Ahhh, a biscuit tin amplifier.. nearly
It might be worth splashing out on something more suitable. Again, CPC stock loads.
Old 3rd June 2014, 10:54 AM   #26
giro1991's Avatar
Ok will do
cpc Order Total: 13.04. Bargain.
I appreicate the input on here, diyaudio really is invaluable.
Old 3rd June 2014, 11:18 AM   #27
Mooly's Avatar
You're welcome. If you are ordering its always worth adding a few extras to the list. Small caps come to mind, useful for extra decoupling.
Old 3rd June 2014, 01:30 PM   #28
giro1991's Avatar
Minimum order quantity was actually 5, so I have 3 extra caps ...
Old 3rd June 2014, 01:54 PM   #29
Mooly's Avatar
Well there you go you see. There are always options You could double up on the caps to make 4400uf or have a C/R/C arrangement using say a 2.2 ohm resistor in the chain.
Old 5th June 2014, 11:17 AM   #30
giro1991's Avatar
what does c-p-c achieve exactly? don't wan't to make it too complex unless it enhances performace....
I'm going to put it in larger tupper ware then, not too keen on metal box.
I remember reading a while ago somewhere, isolating commons is good practice?
On interconnects the external ring is common/gnd, they act as a common line between devices, (in my case amp to 3way and all connected units).
If I wire the common from the 3 boards together but NOT to the GND of the regulator, would this minimise noise?
essentially isolating grounds between devices, instead of them all being lumped together,
suitable power supply for dozen opamps?Hide this!Advertise here!
Are these iron core RF Inductors suitable for power amp power supply? HiFiNutNut Parts 7 26th November 2013 01:56 AM
FS: Dozen 71A and dozen VT-67 DHTs andyjevans Swap Meet 0 24th August 2011 06:49 PM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Suitable regulated/filtered 4volt battery-valve power supply suitable for 6+ valves? Layberinthius Tubes / Valves 0 11th March 2004 08:49 PM
suitable inductors for alephX supply nobody special Pass Labs 15 31st January 2003 12:54 AM
