Active Low Pass
Active Low Pass
Old 6th May 2014, 05:15 AM   #11
PKN is offline PKN  Australia
Originally Posted by Zero D View Post
@ PKN
If you want to use a variable resistor/POT in both positions, you can. But as you showed only one in your initial sketch, i thought that's what you wanted !
Either way will work though.
Thanks mate you guys have been really helpfull. Sorry about the miss understanding.
I will try your circuit you designed for me and report back today.
Your design looks good and I will learn how to implement this in future projects.
Thank you
Old 6th May 2014, 07:56 AM   #12
@ Zero D
I have made the circuit you provided for me. It works
If i was to put a variable resistor on R5 say 5k or 10k this should increase the gain?
I know this works with DC voltages but i am not sure with line level inputs since it contains audio information
Thanks.
Old 6th May 2014, 08:57 AM   #13
R.I.P.
R5 & R4 set the gain of the first stage.
The gain for a non-inverting topology is 1+[R5/R4]
Change either R4 or R5 to change the gain, i.e. change the ratio of R4:R5.
You MUST use a unity gain stable opamp.
regards Andrew T.
Old 6th May 2014, 09:40 AM   #14
Thanks for your reply mate.
I will do some test on this part of the circuit tomorrow and see what happens.
Thank you
Old 6th May 2014, 10:45 AM   #15
Zero D is offline Zero D  United Kingdom
Nice to hear
Yes it will, but due to the limited amount of headroom you have running on 12V, you could easily clip/distort the signal. I doubt whether you will need much gain though.
R5 is the best position to replace the resistor. I would expect a 5k to give you more than enough gain, but if even you choose a 10K obviously you can still set it lower.
Old 6th May 2014, 11:00 AM   #16
R.I.P.
R5 can be lower than R4.
But the gain is still 1+[R5/R4]
regards Andrew T.
Old 10th May 2014, 10:08 AM   #17
Ok Guys i have made the circuit on a PCB. Here are some pictures.
Just got to make the housing.
Old 10th May 2014, 12:08 PM   #18
Hi, looking good !
Did you build it Exactly as in my Post #6 ? Also as i don't see variable resistors on the R5's, what value are the fixed resistors ?
Old 10th May 2014, 12:30 PM   #19
Hi, looking good !
Hey mate thanks. Yeh i used your circuit design. Did a test run today it works good.
I did not use the gain option I am running it on unity gain. It sounded fine with no gain. If i need more i will use the amplifier gain to boost it a bit.
Thanks for all your help. I will post pics of the housing once i made it.
Old 10th May 2014, 01:35 PM   #20
That's good to hear Looking forward to your compleated screenies.
Active Low PassHide this!Advertise here!
Low-pass for Active woofer Gainclone Atilla Chip Amps 23 28th November 2010 01:15 PM
Ultimate Active Low Pass Filter toshiba_nz Analog Line Level 0 26th May 2010 07:25 AM
Tube active low pass crossover Diy martin Full Range 2 2nd November 2006 04:48 PM
Low pass active tube crossover Diy martin Tubes / Valves 2 1st November 2006 03:30 AM
Looking for an active crossover design (low pass only)? Graemedench Solid State 5 28th August 2004 12:25 PM
