Attenuator for Passive pre amp, best sounding solution
Old 1st May 2014, 07:09 PM   #21
irribeo is offline irribeo  Netherlands
Default or another inductive based on elma
happen to see build on dutch forum with this one
Tribute - The final word in audiotransformers
+/-435 euro, built to order (+/-3 months waiting)
Old 1st May 2014, 07:19 PM   #22
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Looking for the best I will used Shallco in place of Elma.
Old 3rd May 2014, 10:35 AM   #23
buzzforb is offline buzzforb  United States
buzzforb's Avatar
From reading, I know both of you to be talented designers. Lets not make a question of choice turn into anything else. There are plenty of examples for both cases and preferences. At a high quality level, we are talking about flavors, not quality. I have heard amps with outstanding numbers that suck and amps that are "musically" crafted that sucked and needed better engineering. Tomato vs tomato.
...Shape the sound , Man!
Old 3rd May 2014, 10:41 AM   #24
Mooly's Avatar
I've deleted a couple of posts. Lets keep personal feeling out of this. Benefit of the doubt this time... that this was just a genuine misunderstanding.
Old 5th May 2014, 10:41 AM   #25
UMarcus is offline UMarcus  Germany
Hi Guys,
many thanks for that useful technical information and suggestion.
There remain some open questions about the transformer solution in my mind
I want to attenuate balanced signals, will the Auto-Transformer work ?
If a transformer is used to attenuate, what happens with the small DC Offset on the input ? I guess it will not transferred to the Output ? So it is possible to keep the Couple C out of the system ?
Marcus
Old 5th May 2014, 10:53 AM   #26
For balanced you need four auto-transformers.
Old 5th May 2014, 11:25 AM   #27
Oh.. ok, that's heavy load of wallet
What is with 'normal' wound att. transformers like
SOWTER ATTENUATOR TRANSFORMERS TVC VOLUME CONTROL
Marcus
Old 5th May 2014, 11:50 AM   #28
DUG is offline DUG  Canada
If they are designed for single ended, yes.
If they were designed for balanced use that would not be the case.
(still expensive IMHO)
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 5th May 2014, 01:34 PM   #29
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
DC offset is a problem for certain types of trafo - mumetal cored without an air gap are the most sensitive. Coupling caps recommended for these. I wind my own trafos on ferrite (SMPSU style) cores, they're only expensive in terms of time spent as the parts (enamelled copper wire, cores) are very cheap. They do have one disadvantage over the more expensive metal-cored ones - their primary inductance tends to be a bit on the low side, whether this is a problem in practice depends on the driving circuit. I haven't found it to be anywhere near a show-stopper and I air-gap mine which makes matters worse...
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 5th May 2014, 05:43 PM   #30
Thanks for you explanation. Could you give more details to understand what are the problem of DC offset ? Magnetization ? How many DC offset usually a problem ?
But at least the DC offset not tranfered to the output, or i'm wrong ?
Attenuator for Passive pre amp, best sounding solutionHide this!Advertise here!
Best-Sounding RC Attenuator & Source Selection System SRMcGee Analog Line Level 0 13th January 2014 08:50 PM
Value of Stepped Attenuator for Passive Amp. xtaljo Analog Line Level 7 22nd October 2012 03:13 PM
Attenuator for passive pre (LEAK ST 20) vincula Tubes / Valves 9 11th October 2012 05:03 PM
Here's my DIY passive attenuator / pre / integrated DAC audiogeekess Analog Line Level 0 7th December 2011 11:22 AM
FS: Dact CT2 10K-2 Stereo Attenuator plus DIY passive pre enclosure GaryAR Swap Meet 6 21st December 2006 07:28 AM
Copyright ©1999-2017 diyAudio
