Attenuator for Passive pre amp, best sounding solution - Page 6 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th May 2014, 04:27 PM   #51
Joshua_G's Avatar
Originally Posted by merlin el mago View Post
Thomas is right sounds better with low impedance sources, for example Legato I/V SE outputs have an output impedance near 0 ohms and sounds superb but when I use Valve Itch MM phono pre with an output impedance of 800 ohms sounds better a ladder switch of resistors.
My cores aren't magnetized & measured inductance is ok: 20H
So you got your answers.
Indeed, 800 ohms output impedance is too high, at least in your setup, with your power amp's input impedance. 800 ohms output impedance may be too high in most setups.
It can be done I use it with Shallco switches in my All fet balanced Borbely preamp. The only issue is that you don't have mute/silence in the first position.
The TVC or IVC is supposed to replace the preamp. I see no point in using both of them.
In any case, mute/silence can be attained with a dedicated witch.
For balanced in to balanced out, you need either balanced TVC or IVC, or, with SE TVC or IVC, two suitable transformers, one at the input and one at the output.
The sound quality will depend on both the quality of the TVC or IVC and on the quality of the transformers used to convert SE to balanced.
Old 18th May 2014, 04:29 PM   #52
I guess like I do with resistors: using cold signal in place of gnd, so gnd not connected at TVC: input gnd connected directly to output gnd.
Input and output ground are the same point on an autoformer.
dave
Old 18th May 2014, 04:51 PM   #53
merlin el mago's Avatar
Thanks Dave I done like you said for SE.
Old 14th August 2014, 10:08 PM   #54
Let me repeat UMarcus' question on the Sowter transformer - I'm also curious...
Someone has experience with the Swoter Transformator [URL="http://www.sowter.co.uk/transformer-attenuators.php"]here ?
Sent from my iPad using Tapatalk
Best-Sounding RC Attenuator & Source Selection System SRMcGee Analog Line Level 0 13th January 2014 09:50 PM
Value of Stepped Attenuator for Passive Amp. xtaljo Analog Line Level 7 22nd October 2012 04:13 PM
Attenuator for passive pre (LEAK ST 20) vincula Tubes / Valves 9 11th October 2012 06:03 PM
Here's my DIY passive attenuator / pre / integrated DAC audiogeekess Analog Line Level 0 7th December 2011 12:22 PM
FS: Dact CT2 10K-2 Stereo Attenuator plus DIY passive pre enclosure GaryAR Swap Meet 6 21st December 2006 08:28 AM
Copyright 1999-2017 diyAudio
