Attenuator for Passive pre amp, best sounding solution - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th April 2014, 08:05 AM   #11
thommy is offline thommy  United Kingdom
Interesting advice abraxalito. "The thing you need doesn't exist and the things everyone uses instead are inherently unsuitable".
I think the OP wants a solution that is actually available for sale.
It was the stereo coffee attenuator that I bought and can't recommend it enough. The comment about resistive attenuators destroying dynamics is just rubbish. Potentiometers and stepped attenuators use resistors to control gain, and with good effect.
Old 30th April 2014, 08:10 AM   #12
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Where was the comment that resistive attenuators destroy dynamics? They certainly limit dynamics for the reasons already stated - introducing greater loading on the source. The implementation isn't at issue, that's assumed to be competent (i.e. blamelessly linear).
@Marcus - a quick search turned up this review that you might find interesting - http://www.enjoythemusic.com/diy/061...ol_modules.htm
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 30th April 2014, 11:21 AM   #13
UMarcus is offline UMarcus  Germany
Originally Posted by abraxalito View Post
I don't know of a commercially available one but sure this would be an excellent DIY project, combining hi-tech uC with low-tech trafo I think relays probably wouldn't be needed, MOSFET switches might well do the job well enough.
But with MOSFET in signal path it is no passive preamp anymore
Old 30th April 2014, 11:27 AM   #14
Originally Posted by Calvin View Post
I´d say a transformer is certainly not the best solution, as the ´best´ always depends on the circumstances, as price, resolution/steps, precision, etc. etc.
- Due to its inductive nature a Autoformer is a nonlinear device. Typically the resolution restricts to a few large steps and size is large. Beeing specialty devices cost is high. Most offers use mechanical switches offering only low comfort, though relais may be used for more handling comfort. Voltage range and power can be high. Due to low comfort, it doesn´t lend itself well to multichannel use.
- Integrated chips like the Muses excel in compactness, number of steps and probabely also in handling convenience, especialy in multi-channel applications. It may be argued about the (sound) quality of silicon resistors and numerous MOS-switches which add THD. Voltage range and power capability is typically small but sufficient for Audio.
- Potis are still the workhorses and come in countless styles. They are compact and may offer some comfort if motorized. Interchannel balance and dB-linearity may be from mediocre to good. For a passive Preamp their varying and rather highish output impedance may be troublesome depending on the load. Typically only short cable runs and higher impedance loads are suitable. Cost and quality may vary over a huge range. Voltage range may be high, Power is typically low, due to the filigrane wiper contacts.
- LDRs offer a compact, low parts number count solution. Number of suitable parts is low, tolerances are high and need screening. Technically an elegant solution allowing for easy handling and comfort and multichannel use.
- Resistor array offer a high dedree of precision. Depending on the chosen number of Steps the number of parts and cost may be high. Build size is not compact.
If intended for a passive Preamp a network should be chosen that offers a lowish and constant output impedance. If a bit-wise weighted network is chosen to reduce the number of switches and resistors, the resistors need to be very tightly tolerated. Only then is a high level precision in dB linearity achieved. Each step itself offers the highest linearity of all solutions as a high quality resistor is without doubt the most linear device one could use. Interchannel balance is excellent and handling and comfort may be high. Adopts well to multi-channel useage. Voltage range and Power can be high.
The final signal quality of the listed solutions depends on the quality of the parts and their implementation. And each of the different techniques has proven good results as well as inferior results. Factors like cost, build size and especially comfort and easy of handling should not be understimated in the evaluation process.
I´ve made excellent experiences with bit-wise weighted switched resistor networks. Sonically its as neutral as one could wish for. At typical listening levels no more than 2-3 resistors are within the signal path. Imho one couldn´t come much closer to the proverbial piece of wire. If it sounds limited in dynamics, its implementation certainly is flawed. Done right the dynamics are outstanding (... as the resistors are the most linear and lowest limiting devices).
jauu
Calvin
Hi Calvin,
many thanks for your explanation, this very interessting.
Did you mean with flawed implemetation that the resistor values (impedance) is wrong in the system ? How i could handle different cases, for e.g. i connect source devices with different impedance to the attenuator ?
Thanks,
regeards
Marcus
Old 30th April 2014, 11:30 AM   #15
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
I made my own LDR , also have some pretty exquisite pots , tried few sorts of switched resistive attenuators , tried them all buffered or not (from both sides , if needed ) and - for my ears - xformer based solution is most fun
that's all I wanted to say in previous post
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 30th April 2014, 11:39 AM   #16
abraxalito's Avatar
Certainly that's one way of looking at it. To me it depends what function the FET's doing - as a switch that's quite different from as an amplifier.
Incidentally 'signal path' is one of those audiohile buzz terms that doesn't reflect reality - that current travels in loops
Old 1st May 2014, 09:27 AM   #17
Calvin is offline Calvin  Germany
Calvin's Avatar
regarding the impedances and loading.
Working in the voltage domain the load impedance seen by the source should be at least 5 times larger as the source impedance.
With typical source devices we see a output impedance of <<1k.
Load impedances >5k will therefore suffice.
A poti network, be it either a classical poti or a switched resistor network offers a constant load impedance (input) of the value R of the poti and a from 0R to R/4 varying source impedance (output) with the lowest values at each end position and the maximum at midpoint position (linear type).
The bitwise resistor network I mentioned behaves different.
Its input impedance varys while the output impedance can be held constant.
If You design such a network for a output impedance of ~1k, the input may have a minimum value of 4-5k and a maximum that rises with the number of Bits.
It may reach a low Meg range.
Anyway, the minimum input impedance is a certainly high enough load for any decent source device.
There's no technical explanation for a dynamics limiting mechanism and its in contrary to my listening experience.
A output impedance of ~1k is on the other hand low enough to drive almost all devices You connect it to with sufficient bandwidth.
Only for loads <<10k and/or cable runs >10m do I switch in a dedicated Buffer stage.
jauu
Calvin
Old 1st May 2014, 09:34 AM   #18
buzzforb's Avatar
Option along with Slagle.
SACThailand
...Shape the sound , Man!
Old 1st May 2014, 11:34 AM   #19
abraxalito's Avatar
Perhaps you mean 'I'm aware of no technical explanation' ? Its not contrary to mine and other people's listening experiences (that trafos sound better than resistive attenuators) and the technical explanation I've given satisfies me - lower impedance loading makes for more supply noise within the output stage of the driving circuitry. At the same time, signal level is decreased by the attenuation. Therefore more noise, less signal. With a trafo the SNR is preserved, provided its shunt inductance is sufficient.
There's another issue with resistive attenuators when put in-line. The ground used for the shunt arm of the attenuator is often a contaminated one - common-mode currents flow along the screens of unbalanced interconnecting cables. Inserting a trafo attenuates the CM currents by virtue of providing galvanic isolation. Auto-trafos though don't convey this advantage.
Old 1st May 2014, 06:41 PM   #20
Calvin's Avatar
I hold this to be self evident, that every human is entitled to err every now and then in its life
No, just kiddin', no pun intended, but You set yourself up for that one.
I'd guess that as everybody has a different listening experience You'll find as many supporters of one principle as You'll find for the other.
Any volume control will have a certain insertion loss.
My network's loss remains <0.5dB up to a source impedance of 1.8k.
If one thinks that this amount of loss is of any noticeable order, well than we hace an issue.
Anyway, I still happily enjoy the good feeling of turning at the wheel of a extremely precise, THD+N transparent, comfortable and sonically neutral volume control ... and btw. did I mention that its IR controllable too?
jauu
Calvin
Best-Sounding RC Attenuator & Source Selection System SRMcGee Analog Line Level 0 13th January 2014 08:50 PM
Value of Stepped Attenuator for Passive Amp. xtaljo Analog Line Level 7 22nd October 2012 03:13 PM
Attenuator for passive pre (LEAK ST 20) vincula Tubes / Valves 9 11th October 2012 05:03 PM
Here's my DIY passive attenuator / pre / integrated DAC audiogeekess Analog Line Level 0 7th December 2011 11:22 AM
FS: Dact CT2 10K-2 Stereo Attenuator plus DIY passive pre enclosure GaryAR Swap Meet 6 21st December 2006 07:28 AM
Copyright ©1999-2017 diyAudio
