TL072 VS NE5532 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th March 2014, 10:19 AM   #1
Default TL072 VS NE5532
I want to build a simple stereo preamp
I have this two op amp .
what would you prefer ? the TL072 or the NE5532 ?
Old 19th March 2014, 10:46 AM   #2
KatieandDad's Avatar
Buy an IC socket and try them both.
Old 19th March 2014, 11:15 AM   #3
I have an IC socket anf I am going to try them both .
I just want to ear from the experience of the members
another question is what would be the best op amp ?
Old 19th March 2014, 11:41 AM   #4
indianajo's Avatar
TL072 will latch up if you get the input too close to the power rail. I did that first thing on my first op amp project. Best start out with 5532.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 19th March 2014, 12:16 PM   #5
Michael Bean's Avatar
The NE5532 is far superior to the TLO72 in just about every way for audio use, only real exception being the 5532s' relatively large input current spec. The TLO72 has a very limited ability to drive a load, it's prone to latch up if the inputs are overloaded, and has many other "features" that make it undesirable for audio in my opinion.
Mike
Old 19th March 2014, 01:05 PM   #6
what would be a better op amp of the ne5532 ?
Old 19th March 2014, 01:15 PM   #7
ypaudio is offline ypaudio  Singapore
OPA2134 or OPA2604 is good opamp
Old 19th March 2014, 03:31 PM   #8
thanks , there is another good op amps ?
Old 19th March 2014, 04:23 PM   #9
indianajo's Avatar
Peavey uses a lot of NJM4560 which sounds good IMHO and has more drive current than the first two. NJM4580 is used by some pro gear suppliers. I'm using MC33078 which are quieter than the industry workhorse 4558's that I replaced. LM4562 is the latest hot item, in the parts bin but not experimented with yet. All these fast slew rate amplfiers require local ceramic disk power supply decoupling, and a 22-47 pf capacitor around the feedback resistor, to keep them from oscillating. I know because the 33078's were oscillating until I did all that.
Old 19th March 2014, 04:57 PM   #10
thanks guys .
i was thinking of building preamp like this with IC socket
you think i should change something ?
where should be the capacitor in the feedback resistors ?
LM4562 vs TL072 and NE5532 ..impossible ? ashok Solid State 20 12th April 2013 06:12 AM
by what to replace the TL072? seb83 Analog Line Level 13 1st January 2012 05:44 PM
TL072 or NE5532 (or TL074) Which is best? pekinin Analog Line Level 1 24th April 2009 10:14 PM
Audient Sumo NE5532, TL072 seeyou Parts 3 29th January 2007 05:24 PM
TL072 vs. 4560? kubeek Parts 8 14th July 2006 07:42 PM
Copyright ©1999-2017 diyAudio
