active bass boost
active bass boost
Old 8th March 2014, 08:24 PM   #1
analogkid455 is offline analogkid455  United States
analogkid455's Avatar
Default active bass boost
I want to build a 2nd order active bass boost circuit for a boost of 10 dB @ 33 Hz.
I found some schematics, but don't you need a buffer stage of some sort? What about an input and output stage?
I don't know much about building these things, but I have built an active crossover before with step by step procedures. I don't really know how it works exactly so I am kinda flying blind here.
I have the components leftover from another project and I know the values of the resistors and caps. I need. I just need guidance on putting it together.
Peerless 5.25", Dayton RS28F-4, active 4th order 1900 Hz, Dayton DVC 310-88 tuned to 20 Hz 4 ft³,active 4th order 133 Hz, Parasond HCA1500, Adcom GFA 535, Dayton DTA-120, Nak MR-1, B&O RX2
Old 8th March 2014, 11:10 PM   #2
Did some more research and after 7 hours I think I have something. Will this work?
Old 8th March 2014, 11:18 PM   #3
Zero D is offline Zero D  United Kingdom
Hi, i can't view it on there, so please upload it directly to here
Old 8th March 2014, 11:27 PM   #4
How do I do that?
Old 8th March 2014, 11:29 PM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
active bass boost
subwoofer filter, gainer auto powe system
sometimes we know very little, and sometimes we know too much
Old 8th March 2014, 11:30 PM   #6
Click on this in the reply, then locate the Pic on your comp by clicking the Browse button & then click Upload
Old 8th March 2014, 11:30 PM   #7
Can you see it now?
Old 8th March 2014, 11:32 PM   #8
Ah! I think I have it now! Thank you1
Old 8th March 2014, 11:35 PM   #9
I can see it now. That's a High Pass Filter, not a boost circuit. Plus there's a lot wrong with it. I have to go eat now, but i'll post back to you later
Old 8th March 2014, 11:59 PM   #10
R.I.P.
A peaking high pass is generally better than a peaking all pass in the bass.
For higher boosts a peaking second order is best combined with a 1st
order low pass step filter, often very easy to do passively.
rgds, sreten.
active bass boostHide this!Advertise here!
Bass boost in portable active speakers? Dominique Multi-Way 41 22nd April 2006 08:04 PM
bass boost odysseybmx414 Chip Amps 3 26th August 2005 09:05 AM
Bass Boost Q UNDERSTANDIN Subwoofers 5 26th July 2005 08:49 PM
bass boost lawbadman Solid State 4 29th August 2003 02:20 PM
