Humming DRV134 balanced output.
Old 2nd March 2014, 01:31 PM   #11
russc is offline russc  England
Thanks Andrew.
I have now re-tested first amp with identical lash-up to 2nd amp test - works fine.
Only difference between successful & unsucessful test is 1mtr of twisted speaker cable!
Can that cause a class D amp to oscillate?
Old 3rd March 2014, 08:23 AM   #12
R.I.P.
I don't know.
I have read a few ClassD posts here and the section in Cordell's book.
I still know nothing about ClassD design.
regards Andrew T.
Old 3rd March 2014, 08:24 PM   #13
Andrew - Sorry to be a pain but I cannot find the grounding article you mention.
Can you direct me? Thanks.
Old 3rd March 2014, 10:57 PM   #14
Speedskater is online now Speedskater  United States
Speedskater's Avatar
It's hidden in the articles section:
Audio Component Grounding and Interconnection
David Davenport - 21st April 2010
Kevin
Old 4th March 2014, 06:48 PM   #15
Thanks, got it. I have printed in full to study.
I have a lot to learn.
Old 5th March 2014, 06:31 PM   #16
Dumb question and I cannot see it in the Grounding Article:
I ground the xlr sockets pin 1 to chassis. I ground the power amp pcb to chassis star ground. I sort out the pre-amp grounds.
I have a short lengths of balanced screened cable from pcb to xlr chassis sockets. Do I ground these at pcb or at chassis socket?
Old 5th March 2014, 06:55 PM   #17
R.I.P.
Screens to Chassis at both ends.
Keep the audio on the PCBs.
H.Ott tells us that sometimes one end of the screen may need a capacitor coupling to Chassis. The other end is still to Chassis.
What does this mean?
regards Andrew T.
Old 5th March 2014, 07:08 PM   #18
The Abletec amp is complete with power supply. The pcb has 6 mounting holes. 2 must be insulated. 4 are ground plane and have bright solder around the screw holes. I thought I was being smart mounting on insulated stand-offs. Now I know from the grounding article it should be connected to chassis. The mains cable earth wire is screwed to chassis (a star of 1 wire).
I could - a) run a short length of wire from pcb ground plane to this screw, b) replace the nearest stand-off (about 20mm away from earth screw) with a spacer and long screw thus grounding the pcb at 1 point or c) replace all 4 stand-offs with spacers and long screws.
Old 6th March 2014, 07:43 AM   #19
R.I.P.
Probably better to have all the standoffs making contact with the Chassis floor.
No need to take the Chassis connections to the Safety Earth.
regards Andrew T.
Old 9th March 2014, 10:26 AM   #20
Grounding sorted. Zero hum. Success.
Thanks for all the help.
Preamp casework next - wooden mock-up before fabricating metal case.
Humming DRV134 balanced output.Hide this!Advertise here!
Balanced Line Driver with DRV134 chris2 Analog Line Level 88 30th July 2014 12:44 PM
INA134-DRV134 balanced preamp raul_77 Analog Line Level 7 4th May 2012 12:30 AM
Balanced line driver (DRV134) and noise ettos Analog Line Level 34 16th October 2011 10:20 PM
Balanced -> Unbalanced DRV134 the best? peranders Parts 6 11th November 2009 04:54 PM
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 05:55 PM
