Opamp Having Oscillation - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th February 2014, 02:12 PM   #21
Did it Himself
richie00boy's Avatar
You are missing the point that Calvin and myself are making. We both understand the circuit, but you are reading differently what we are writing.
Put 13.5k from U2 output to inverting input.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 19th February 2014, 03:20 PM   #22
Send a message via MSN to chchyong89
Hi Richie00boy,
I am sorry if I was misunderstood both of you. So do you actually mean the feedback loop below doesn't work?
Adding 13.5k just can't realize the fully differential output capability. When only SE signal is provided, one output is larger than the other.
www.stoneracoustics.com
Old 19th February 2014, 03:27 PM   #23
Did it Himself
That is a different circuit to what we have been discussing.
Old 19th February 2014, 05:32 PM   #24
same
Old 19th February 2014, 07:31 PM   #25
I wish people would learn to draw schematics in some sort of rational conventional way
I realise that the original schema in this thread is how one can fling it together to stuff it into a sim, but my old-fashioned brain finds it too confusing.
I have simplified it to MY tastes and experience. Sorry I have nothing but a pen to hand.
It seems to me that this circuit is very problematic.
There are two feedback paths for U2 - via U1 and U3 in parallel. I do not see how stability can be achieved. Because U2 is open loop (locally), its o/p will .... do what?
I it is not clear to me what is being attempted here!
Old 19th February 2014, 07:33 PM   #26
Did it Himself
Originally Posted by chchyong89 View Post
same
No it's not. The circuit we have been discussing has 3 op-amps. That has two.
Old 20th February 2014, 04:04 AM   #27
Trace the signal in and the feedback path.
Finally I managed to stop the opamp from ocsillation by adding C3 to compensate the circuit. The SAW wave oscillation is gone completely. Zoomed in the scope to 2mV/div and only can read some "dirty noise" that is less than 1mV.
Both output is giving same output voltage amplitude when SE source/ Balanced source is used. So this is what I wanted in the earlier time, a fully differential design.
Old 20th February 2014, 04:57 AM   #28
Ya, I am still learning to draw it nicely in the software, but sometimes I am too lazy for that
At very first, this circuit looks problematic on my eyes too, 'dual active unity gain feedback' loop( I don't know how to call it). But after look into the circuit, well it just worth to give it a try, and I managed to make it stable and works now
Performance wise, I have yet to measure it.
Old 20th February 2014, 07:37 AM   #29
Did it Himself
Yes, and yet again you totally miss the point I have been making. The circuits are not the same
Glad you have a fix. What a surprise it is in essence very similar to what we were telling you to do...
Old 20th February 2014, 07:49 AM   #30
Oh is it?
Rolling opamps: DIY DIP-14 to two DIP-8 socket converter for quad opamp to dual opamp ygg-it Chip Amps 2 17th January 2014 12:27 PM
PGA2310 - PGA2311 - CS3310: version without OPAMP for outdoor OPAmp connection wanted tiefbassuebertr Analog Line Level 11 9th July 2013 05:50 AM
Which opamp was used for the Adcom 6AA opamp ? gaetan8888 Digital Source 3 20th December 2010 07:17 AM
Opamp oscillation Sheldon Solid State 21 13th February 2007 02:29 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Copyright 1999-2017 diyAudio
