Opamp Having Oscillation - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th February 2014, 10:23 AM   #11
Mooly's Avatar
Originally Posted by chchyong89 View Post
This doesn't work, actually I intended to make it looks like a fully differential opamp. Like Opa1632 etc...
If it doesn't work as I describe then you have other construction errors.
Installing and using LTspice IV. From beginner to advanced.
Old 19th February 2014, 10:24 AM   #12
Send a message via MSN to chchyong89
Originally Posted by donpetru View Post
There are many connection errors. You should give up the U2 because, as you draw schematic, +U1 and +U3 should be connected to GND. In this case, U2 makes no sense.
Hmmm.. I am biasing the voltage into the mid rail.
www.stoneracoustics.com
Old 19th February 2014, 10:32 AM   #13
donpetru's Avatar
I saw it, but U2 output that you think will 0V?! I think not. Here's your mistake, therefore I think your circuit should work correctly with some changes, if you have powered with voltage + /-12Vdc (or something like that).
AV400v2 and GX400 audio amplifier projects
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums
Old 19th February 2014, 10:36 AM   #14
If you want made fully differential opamp, then give up your schematic and try to develop something like this:
Ya, i read through this in the earlier time. But I don't like it with a reason (perhaps it's my personal reason) :
1. I am running on single rail. I need to bias the +in into midrail. And with it, my Source need to seen into the midrail's resistors during the path into the +in point.
2. And the simulated result doesn't seem like it's in similar amplitude for both output when I am running off from a SE source.
Old 19th February 2014, 10:45 AM   #15
U2 is not intended to be the mid rail generator
Old 19th February 2014, 10:52 AM   #16
donpetru's Avatar
Output amplitude is not the same for the two operational amplifiers because their input is not found same voltage signal.
What type of application you want to use this circuit?
Old 19th February 2014, 10:57 AM   #17
Mooly's Avatar
Then it will not work as it is.
Old 19th February 2014, 12:34 PM   #18
I think I didn't stated up my goal properly in the early stage. Sorry for it.
I would want it to be a fully differential opamp. This is a design that I got it from the google image, and it looks simply super brilliant(to me).
To make you further clear about what I want, I change it into dual rail, and you can easier to read what's U2 actually doing in the circuit. It's not just simply providing a vref/Vmid into the non-inverting pin.
U2 is not under open loop condition, it's under unity gain by taking the output from U1 and U3 (either one act as input and output. ) and feedback into the inverting pin. (As what I can read)
Under this design, no matter which input is having larger or smaller signal, the output differential signal will still be 'compensate' by the U2 and giving the same output amplitude from U1 and U3.
what's making me suspect now is maybe the 4558 is not stable under unity gain and causing it oscillate badly, I guess.
Old 19th February 2014, 01:31 PM   #19
Calvin is offline Calvin  Germany
Calvin's Avatar
Id say the reason that Your circuit of #1 doesnt work is due to U2 working virtually open loop.
U2 is intended to be just a lowimpedance voltage source (voltage follower) suppling the potential it finds at its positive input 1:1 to the inputs of U1 and U3.
As such U2 needs a direct feedback path from its output to its negative input with a feedback resistor of value (R7||R8).
This structure is just a simple 2-channel gain stage with a common Bias offset generator.
If You gnd the Input at C2, U3s Output will be simply the DC Offset supplied by U2.
It certainly is not a fully differential amplifier like the cited OPA1632 where You may ground any of its inputs and still create a differential output.
jauu
Calvin
Old 19th February 2014, 02:21 PM   #20
jauu
Calvin
Hi Calvin.
The circuit actually work, and tested to work. the problem is , it's not stable and oscillating.
The U2 is not completely use for creating the potential for DC level of the Vout+ and Vout- ONLY. The R1 and R2 is there for it's reason in this design.
"U2 needs a direct feedback path"
I understood what you and mooly trying to say, you are creating a low impedance 'virtual ground buffer' there by doing so. But it's not the purpose of doing it here, in this design.
This structure is just a simple 2-channel gain stage with a common Bias offset generator. - No, not that simple in this design.
"It certainly is not a fully differential amplifier like the cited OPA1632 where You may ground any of its inputs and still create a differential output."
Yes this circuits works that way, completely and very fine. Just the stability issues. I am figuring, what's and which stage actually make it not stable and oscillate.
Last edited by chchyong89; 19th February 2014 at 02:32 PM. Reason: I am a little bit too harshed.
Rolling opamps: DIY DIP-14 to two DIP-8 socket converter for quad opamp to dual opamp ygg-it Chip Amps 2 17th January 2014 01:27 PM
PGA2310 - PGA2311 - CS3310: version without OPAMP for outdoor OPAmp connection wanted tiefbassuebertr Analog Line Level 11 9th July 2013 06:50 AM
Which opamp was used for the Adcom 6AA opamp ? gaetan8888 Digital Source 3 20th December 2010 08:17 AM
Opamp oscillation Sheldon Solid State 21 13th February 2007 03:29 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 03:15 PM
Copyright 1999-2017 diyAudio
