How to reduce measured noise floor in my DAC/opamp circuit
Old 21st February 2014, 09:04 AM   #11
R.I.P.
Some, or maybe many, DACs go into mute when the signal drops below a defined level.
If the tested DAC is muted during the "between" signals periods then the test is flawed.
How do you know that the computer controlled testing is measuring a live DAC or a muted DAC?
regards Andrew T.
Old 21st February 2014, 02:58 PM   #12
maxw is offline maxw  United Kingdom
maxw's Avatar
I guess I would just trust that such a widely used application like RMAA or Arta does it properly
How to reduce measured noise floor in my DAC/opamp circuitHide this!Advertise here!
Help needed for modifying DAC-opamp-tube circuit brianhauris Tubes / Valves 4 8th October 2013 02:22 PM
noise floor analyser vincent_brient Vendor's Bazaar 6 19th September 2011 08:57 AM
tripath noise floor. lbstyling Class D 10 23rd September 2010 04:54 AM
noise floor problem johndiy Solid State 12 31st August 2006 01:32 AM
Who's measured the noise on their RIAA preamp? CeramicMan Analogue Source 20 19th February 2004 06:35 PM
