The Kuartlotron - keantoken's simple error-correction superbuffer
Old 4th June 2018, 02:03 AM   #921
keantoken is offline keantoken  United States
keantoken's Avatar
Is this what you were doing? Notice the bootstrap is taken before the 47R resistor and there is no input shunt resistor (input must be DC coupled). You could also remove the 47R resistor entirely, it is there to help with cables.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 4th June 2018, 07:32 AM   #922
patriz is offline patriz
patriz's Avatar
I used thisl one with a 10k pot at the input.
Old 4th June 2018, 10:19 AM   #923
Project16 is offline Project16  France
Project16's Avatar
Hello everyone
After some private message requests for the manufacturing files and Sprint Layout, I decided to make them available for everyone.
On the images the name 'KEANTOKEN' has a small error and it is repaired in the attached files in the archive.
The first version I made and hand made that works perfectly is visible here but I made some small aesthetic and practical changes.
Originally Posted by adason View Post
Interested, if some boards are available.
A small production of 10 printed circuits is launched and I will have two to three pairs available in some time.
Regard's
Old 4th June 2018, 10:22 AM   #924
keantoken's Avatar
That is a buffer, not a LP filter. What did you do to make it a LP filter? You may just need to remove the 10k resistor.
Old 4th June 2018, 10:36 AM   #925
patriz's Avatar
Hi Kean , thank you. Sorry I wasn't clear enough.Your schematic in post 921 it is just what I used in the LP active crossover , except L1 and L2 and 1M shunt input resistor . My question was about the buffer used as preamp with volume control, not the buffers used in the active crossover.
Old 4th June 2018, 10:41 AM   #926
keantoken's Avatar
Okay. Well that is interesting, since it's the first time I've heard of a problem with the bass. The boards I sell use a 100k input resistor, the original circuit used 10k because some early users wanted to use it DC coupled. If you are using an input capacitor try using 100k instead of 10k.
Old 6th June 2018, 01:09 PM   #927
Project16's Avatar
Hello everyone
Visibly a small trace poses problem for some manufacturers with the track connected to the ground plane, so I modified the layout to correct this problem.
Old 13th June 2018, 09:18 AM   #928
silasmellor is offline silasmellor  Denmark
Hey Project16, do you still have boards available for this? How much of an issue is 12V in, or should that be dropped to 10V?
Old 13th June 2018, 10:44 AM   #929
jameshillj is offline jameshillj  Australia
I know the pcb design programs are designed for production assembly, not diy and this is a bit late in your design procedure but is it possible to increase the size of the donuts and also the space between the donuts and the surrounding 'planes?
As it is, the small donuts and narrow clearances increase the chances of a 'short' plus when altering components, it's rather difficult to avoid board damage
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
