The Kuartlotron - keantoken's simple error-correction superbuffer
Old 23rd February 2018, 03:04 PM   #891
beardman is offline beardman  Denmark
Hi
can the Buffer be used on output on DDdac pcm1794 ,,any body now that ?
Old 23rd February 2018, 04:13 PM   #892
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Why not? It has already gone I/V conversion so you can follow with whatever you want. But you would want different psu's.
Old 4th March 2018, 10:27 AM   #893
hkknudsen is offline hkknudsen
I believe I've read it somewhere, but I can't find it; can the Kuartlotron drive several outputs simultaneously, so I can use it to attach a subwoofer?
Old 4th March 2018, 10:36 AM   #894
keantoken is offline keantoken  United States
keantoken's Avatar
Yes, that should be fine.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 5th March 2018, 02:01 AM   #895
I had some resistors bringing down my voltage just a hair (big resistors). I've got to say that I pulled them out because I was experiencing some problems with the volume I was trying to play at. Now that my voltage is a bit higher, I can play without that problem. It's my opinion that the voltage recommendations are too low unless you have 91db or better speakers.
I have a 2x12v transformer, and in retrospect I'd love to increase it - probably will at some point.
I'm using the older boards that had the error between some pico cap and resistor, without the regulators.
Old 6th March 2018, 12:10 PM   #896
keantoken's Avatar
If you must increase the voltage, trim R5 so that TP is half of V+.
Old 6th March 2018, 08:21 PM   #897
Done.
I'm at 12.71v and 6.35v now. If there is a sonic change, I'm not completely certain. Maybe slightly smoother and easier to read, but it took a minute to do with my double stack layout so it wasn't very back to back.
My caps are only 16v. I'd have to upgrade them to upgrade voltage. We'll see
Old 6th March 2018, 08:24 PM   #898
PRAT may be better.
Old 7th March 2018, 01:11 AM   #899
audiostar is offline audiostar  United States
keantoken,
I sent you a PM.
Old 20th May 2018, 03:29 PM   #900
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Hello Kean
I would like to implement the kuartlotron in the output of my new paradise build that has +-18Vcc
Can I power the kuart with these voltages without major surgery ?
RC
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
