The Kuartlotron - keantoken's simple error-correction superbuffer
Old 29th September 2016, 07:55 AM   #731
R.I.P.
Originally Posted by luxury54 View Post
guys I apologize for the stupid question, but where is this buffer reccomended to be placed at best? between the preamp and the final amp? between the analogue source and EQ/preamp?
A Buffer gets added to the output of a stage that is incapable of driving the cables that follow it.
regards Andrew T.
Old 29th September 2016, 07:57 AM   #732
R.I.P.
Originally Posted by nikosokey View Post
Also i have a few questions
When we have the need to put a buffer between source and amp?
my source has 0.1Ω output impedance and my amp 100ΚΩ its necessary the buffer?
The source with 0.1Ω output impedance should see a constant load ?
Can i put the pot after the buffer between buffer and amp lets say 10ΚΩ pot?
I have seen a few of your posts stating this 0.1ohm for output impedance.
What kind of output stage does your DAC have?
regards Andrew T.
Old 29th September 2016, 07:58 AM   #733
keantoken is offline keantoken  United States
keantoken's Avatar
Engineers would say there is usually no need for a buffer, unless you're driving long cables or you have a high impedance input like a phono cartridge. One good place for it is after the volume control to reduce the source impedance seen by your amp. It can be good to have a few available as a diagnotic tool as well.
With a direct connection there is no technical reason to use a buffer. Since the volume pot can have a high output impedance, it is usually best to put the buffer after the volume pot.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 29th September 2016, 08:02 AM   #734
keantoken's Avatar
Originally Posted by AndrewT View Post
Then post696 suggests you add a link to post1. But that has still not been done !
Actually I did right after you posted that. I even updated that link earlier today.
Old 29th September 2016, 08:06 AM   #735
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Hi Andrew
AK4490 Mirand Discrete..
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone ,Preamplifier Dispre 2 - JFET, DCB1 SALAS, D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp.
Old 29th September 2016, 08:07 AM   #736
R.I.P.
Your link does not work.
Go to post695.
click on the post number and the Browser takes post695 to the top of your screen,
Right click on the post number. Firefox gives the option to Copy Link Location, Click on that.
Paste that into post1
IE offers the option after right click of copy shortcut.
Click on that and then paste into post1.
regards Andrew T.
Old 29th September 2016, 08:34 AM   #737
tributeaudio is offline tributeaudio  China
Banned
Hi, Are boards available through DIY audio or you. Cheers
Old 29th September 2016, 09:00 AM   #738
R.I.P.
Hi Andrew
going to
AK4490 USB Dac with dsd support – Without shield | Mirand Audio - Solidstate designs
does not tell me what kind of output stage is fitted to your DAC.
regards Andrew T.
Old 29th September 2016, 09:13 AM   #739
nikosokey's Avatar
going to
AK4490 USB Dac with dsd support Without shield | Mirand Audio - Solidstate designs
AK4490 USB Dac with dsd support – Discrete DIFF/SE shield, PCM Filter setting | Mirand Audio - Solidstate designs
Old 29th September 2016, 10:08 AM   #740
R.I.P.
found it:
Output stage – Fully discrete differential and single ended
Thin Film resistors 0.1%
PPS capacitors 2%
Discrete SSR relays for muting
6 discrete JFET input opamps running in class A
Now where does it say 0.1ohm output impedance?
regards Andrew T.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
