The Kuartlotron - keantoken's simple error-correction superbuffer
Old 29th September 2016, 12:12 AM   #721
bear is offline bear
expert in tautology
bear's Avatar
well maybe my computer is possessed?
That link brings you to the first post... and the link on the first post brings you to... the first post. <lost>
Wanted to mention that you might edit that text and put a date WRT the boards availability?
So, what's the deal, PM you or??
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 29th September 2016, 12:20 AM   #722
expert in tautology
bear's Avatar
Fwiw, post 695 is: POST 695
and appears on page 15 of my browser...
Still would like to know who is supplying the boards and pricing.
Is there a Group Buy thread?
_-_-bear
Old 29th September 2016, 12:29 AM   #723
expert in tautology
bear's Avatar
Ok, so no substitute for reading back a few pages: ORDERING INFO
Assume this still stands?
_-_-bear
Old 29th September 2016, 01:13 AM   #724
keantoken is offline keantoken  United States
keantoken's Avatar
Post links have never quite worked right on this site...
I designed the current PCB. It's a mono 5x5cm board. Pricing is $3 shipping plus $8 per board. PM me your info. I will try to get something more convenient set up.
Construction and BOMs:
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 29th September 2016, 04:24 AM   #725
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
My browser bounces to the first page, then skips to the correct page and post. Maybe you're not waiting long enough? Maybe you're on that horse **** satellite internet so it takes forever?
Old 29th September 2016, 04:33 AM   #726
keantoken's Avatar
I can truncate the link so that it takes everyone to the right page. The problem is, that only works when the link is not on the first page of the thread! The mind boggles. What a pain. Try it again, I did something else.
Old 29th September 2016, 05:55 AM   #727
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by BenY View Post
Why is it recommended to use the Fairchild transistors? What is wrong with the ON Semi ones?
OnSemi owns several fab plants, bought at different times, and situated at different locations. From vendors, it occurs that some are parts shipped at half-specs, and rather too often. This is especially inconvenient if you had expected matched pairs. I'm finding it unnecessary to say more on that.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 29th September 2016, 07:18 AM   #728
luxury54 is offline luxury54  Romania
guys I apologize for the stupid question, but where is this buffer reccomended to be placed at best? between the preamp and the final amp? between the analogue source and EQ/preamp?
== There are no limitations to the self except those you believe in ==
Old 29th September 2016, 07:37 AM   #729
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Also i have a few questions
When we have the need to put a buffer between source and amp?
my source has 0.1Ω output impedance and my amp 100ΚΩ its necessary the buffer?
The source with 0.1Ω output impedance should see a constant load ?
Can i put the pot after the buffer between buffer and amp lets say 10ΚΩ pot?
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone ,Preamplifier Dispre 2 - JFET, DCB1 SALAS, D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp.
Old 29th September 2016, 07:54 AM   #730
R.I.P.
Post722 has a link that takes me to posts695
Here is the link
this link also took me to post695.
Then post696 suggests you add a link to post1. But that has still not been done !
regards Andrew T.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
