The Kuartlotron - keantoken's simple error-correction superbuffer
Old 25th September 2016, 08:35 PM   #711
keantoken is offline keantoken  United States
keantoken's Avatar
Originally Posted by nikosokey View Post
Hi Keantoken
I use ON Semi
I need to make changes for better results?
The Kuartlotron webpage schematic gives instructions for changing resistors to accommodate Vbe. There is also a possibility it could be unstable, but I haven't seen it so far. You may get acceptable results without any changes, although your input transistors will probably be running low bias.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th September 2016, 05:27 AM   #712
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Thanks Kean
i will decrease the R1 nad R2 to 52Ω or 47Ω....and i will readjust the R5 trim ...
When i change the 15pf to mica cap i put 5pf the only available , the sound change for the best ,sound completely clean...now
the 25mv on multimeter are the output from my amplifier Golmund clone 9.2.
with SuperBuffer after my DAC AK4490.
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone ,Preamplifier Dispre 2 - JFET, DCB1 SALAS, D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp.
Old 28th September 2016, 10:43 AM   #713
nikosokey's Avatar
Yesterday i had make some tests with Buffer after the dac 4490 Discrete (the Dac has 0.1Ω output impedance) i put on buffer 100ΚΩ without any pot just the buffer
at the high levels volume via foobar understand some correction of THD if that makes any sense.
Old 28th September 2016, 09:02 PM   #714
jls001 is offline jls001  India
Originally Posted by Destroyer OS. View Post
Um no...
I'm reporting I don't have any harshness because Keantoken noted higher voltage can come across with a harsher sound. I'm only at 12.5v.
I'm currently playing around with a shuntreg kit I assembled and tried a couple of 'non-recommended' voltages to power the Kuart.
+/-14.3V sounds too in-your-face, too forward-sounding for my liking, though it did bring drive, flow and much better retrieval of lower level details. But the airiness for which I so loved the Kuart was lost.
Toning it down to +/-13V restored the earlier laidback presentation (with the LM317/337 PSU), while retaining much of the new-found liveliness, drive, flow, and better resolution, but more importantly, restoring the airiness.
I haven't got down to checking if the transistors are overheating, or if the DC offsets have gone up, but the sound is definitely more likable than before. Unfortunately with my existing transformer 13V is the lowest the shuntreg can provide. I also need to re-do the TP adjustment (of half Vcc).
Old 28th September 2016, 11:04 PM   #715
bear is offline bear
expert in tautology
bear's Avatar
Sorry, but without reading back lots of pages, where does one find the boards??
Maybe Keantoken you'd want to put a link into ur sig page that goes to a page that links to the boards, or something along those lines?
I'm interested enough in the circuit to try some out!
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 28th September 2016, 11:14 PM   #716
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Just PM him.
This post has all the info you need.
Old 28th September 2016, 11:20 PM   #717
expert in tautology
bear's Avatar
the link goes to the top of the page? <lost>
_-_-bear
Old 28th September 2016, 11:44 PM   #718
Give it a second and it should go to the correct post, which is 695, on page 70.
Old 28th September 2016, 11:48 PM   #719
keantoken's Avatar
Higher voltages will increase potential thermal mismatch and possibly cause thermal distortion. Furthermore the bias chain is made for +-10V so if you go much higher you won't be able to dial in TP. If you like the sound at a higher voltage, try deliberately putting TP 2V high or low.
Old 28th September 2016, 11:50 PM   #720
keantoken's Avatar
I also put a link in the first post:
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
