The Kuartlotron - keantoken's simple error-correction superbuffer
Old 22nd July 2016, 09:13 PM   #611
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
Originally Posted by keantoken View Post
Kmultipliers will work to drop 12V down to 10V for this circuit, if you load them with 470R 500mW resistors to get above the minimum load.
R1? or across the outputs?
Old 22nd July 2016, 09:15 PM   #612
keantoken is offline keantoken  United States
keantoken's Avatar
It's a load. It goes at the output.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th July 2016, 07:46 AM   #613
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Originally Posted by Destroyer OS. View Post
I'll let you know if I have any "harhness" but I wouldn't make that claim so far...
This does not do anything disproportionate.
Harshness is not on this page.
An epic length list of what it won't do is entirely appropriate for a buffer; and, this circuit is a lovely and helpful buffer. It is rather good at refusing to do anything else, so you won't be getting any harshness here.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 26th July 2016, 07:56 AM   #614
That looks like English, but I still need an interpretation to understand it... sorry.
Old 26th July 2016, 08:15 AM   #615
I built it wanting a bass boost.
Wasn't entirely disappointed.
It boosted everything's resolution.
Well, everything was slightly clearer.
Why else have a buffer anyway?
Slight problem is that it didn't boost the bass disproportionately.
Oops!
I should have asked for a bass booster.
I didn't get it.
Also,
If you wanted more harshness, you're not going to get that.
This may be a great buffer but it absolutely sucks at signal modification capacity.
Can re-try with the southern version if you're sure. Wouldn't want to try that on the first go, so if that's the thing to do, then just mention it.
Old 26th July 2016, 09:01 AM   #616
R.I.P.
Is that any better?
regards Andrew T.
Old 26th July 2016, 09:15 AM   #617
Um no...
I'm reporting I don't have any harshness because Keantoken noted higher voltage can come across with a harsher sound. I'm only at 12.5v.
And if you have a lack of bass maybe you're looking in the wrong place. It's an error correction buffer. So ya, I doubt it tolerates silly attempts to change the signal.
Old 26th July 2016, 04:56 PM   #618
keantoken's Avatar
Hi Dan, tell me if you want a pair of Kuartlotron boards. I still feel a bit guilty about your disappointment with the Kuartlotron, with it not being a bass enhancer and all... But I swear, that one time it really did!
Old 27th July 2016, 09:24 AM   #619
lohk is offline lohk  Europe
lohk's Avatar
Will it make sense to use a silver mica cap for the input snubber?
/lohk/
Old 27th July 2016, 07:51 PM   #620
keantoken's Avatar
Any 15pF capacitor will work. The general guidelines apply here. With a high source impedance a very bad capacitor could cause distortion.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
