The Kuartlotron - keantoken's simple error-correction superbuffer
Old 17th February 2014, 09:50 PM   #21
keantoken is offline keantoken  United States
keantoken's Avatar
2700k=2.7M
LTSpice does funny things if you use the M suffix.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 17th February 2014, 09:56 PM   #22
Zero D is offline Zero D  United Kingdom
2700k=2.7M
OK
It's fine in Multisim
Old 17th February 2014, 09:59 PM   #23
keantoken's Avatar
Originally Posted by brianco View Post
With Joachim and Marina's approval of the early design coupled with the improvements you have in mind - it does appear that you have a very viable design. Congratulations.
I may well try a PtP build as a switching + volume control. In the meanwhile I would like to see the initial PS design provided you feel like sharing.
Good luck.
A friend has repeatedly told me this buffer is extremely tolerant of bad power sonically, so I don't know how much of a power supply is needed. I'm satisfied with a passive zener supply at most, but admittedly I have not played with the power supply much.
Can we have a show of hands on which type of supply you guys want? The original version was made for DC for Joachim, but I've had a few requests for a single-rail supply version. I want to stick with dual-rail because that makes capacitors optional, but I understand a single-rail option would be convenient for many.
Old 17th February 2014, 10:25 PM   #24
Default Power Supply
Why not try it with your Kmultiplier rail filter, preceeded with possibly a Regulator, as i suggested in your Kmultiplier thread last year.
Also i'm guessing that most applications would prefer a Dual Supply ?
I just simmed it with + - 17V & it looks fine.
Old 17th February 2014, 10:39 PM   #25
keantoken's Avatar
The simulator won't show the thermal mismatch which is what the biasing arrangement is for. That's why I put the TP node at half the positive supply. If you change the supply voltage you probably want to either remove the bias circuit or adapt it to the new supply voltage (ideal solution).
Other reasons for +-10V:
1: It keeps dissipation and therefore dynamic and static thermal drift to a minimum.
2: I found going over 10V had a harsh sound that I couldn't track down, and wasn't even necessary. Perhaps after all the improvements since then it will be fine? I don't know.
The Kuartlotron doesn't draw enough current for the Kmultipliers. You would need 470R resistors from power to ground to draw about 20mA to put the KM's in a good range.
If I wanted just the extra PSRR of the Kmultipliers, I would just use BC3x7-40 C-multipliers, potentially with zeners for regulation, and possibly choose the ground references strategically depending on the ground topology of the system.
Old 17th February 2014, 11:44 PM   #26
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Default An approximate inductor.
Originally Posted by RCruz View Post
Any recommendations on what to use for the coils L1 2uH ?
I have a 3 step plan for that:
Get an AA battery from the flashlight.
Wind 15 turns of 20ga wire around it.
Put the battery back in the flashlight.
You will have an *approximately* 0.002mH inductor.
Disclaimer: My math skills are awful, so this might need checked--can someone check it with an inductance meter?
P.S.
20ga is thermostat wire from the hardware store.
A 28" piece of 2 conductor may provide enough for stereo.
Tip: Tape the wire to the battery and then rotate the battery.
20ga is a nice solid copper material also great for small signal needs.
You can approximately measure wire gauge with a closed wire stripper tool.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 18th February 2014, 12:01 AM   #27
Martina Schoener is offline Martina Schoener  Germany
Martina Schoener's Avatar
image.jpgHallo Joachim, hallo Keantoken
just give you a picture of my working place and a "certain "
buffer in it
The sound has a level of undisturbed, clear information, that is only mached by the very best line stages I came accross in my "Audio Life"
the "musical correctness" in tonality, dynamics, punch, details, focus and imaging is just striking! - in my system the height matters and now, with the newer version its there and also 3D is there ( soundsources/instruments are placed before, behind, above and in between my speakers)
and when this happens a lot of things went into the right direction...
( I use a ZDL 5 way, time correct, and " almost" phase linear speaker as my main monitor and played this weekend with the Kiso speakers - which created a lot of fun - actually real "Joy")
Thanks for your work ....
and my "Amplifier" thanks you too, as it loves being provided with signals from such a wonderful source
Martina
Old 18th February 2014, 12:05 AM   #28
Easycheesy plan for power:
Those nice "MC" regulators from OnSemi are available in 9v positive and 9v negative.
A standard silicon diode, such as 1n5* in series to the center pin will boost it to 9.65v, which is well within tolerances. So, there's an uncomplicated and doable plan for power.
Old 18th February 2014, 12:20 AM   #29
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
It could work on a floating suppy. So 20V with no ground connection.
Old 18th February 2014, 12:23 AM   #30
Martina, the pictures are a bit small. Can you generate a PNG ?
Martina, you can try my floating idea.
Just cut the ground wires from the batteries that go to the copper ground plane.
REDUCE THE VOLUME BEFORE YOU DO THAT:
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
