The Kuartlotron - keantoken's simple error-correction superbuffer
Old 17th February 2014, 08:38 PM   #11
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Can we avoid the input cap ?
RC
Old 17th February 2014, 08:42 PM   #12
keantoken is offline keantoken  United States
keantoken's Avatar
I can make a version for that, but it would be sending signal through power supply caps and I don't like to do that. Do you have an example of this kind of circuit?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 17th February 2014, 08:44 PM   #13
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
You can do it with J-Fets of cause.
Old 17th February 2014, 09:10 PM   #14
keantoken's Avatar
Guys, I'm suddenly having some interesting ideas, so the Kuartlotron is still very much an evolving circuit. Anyone who would be interested in testing out different versions should speak up. I have one idea to increase PSRR and another to make trimming simpler, but at the moment I can't test all these ideas and don't like to post untested circuits.
Old 17th February 2014, 09:19 PM   #15
I can build P-P fast.
Old 17th February 2014, 09:31 PM   #16
keantoken's Avatar
Well then, try a 560R resistor in series with C1. This causes the error correction to compensate for PSRR. Simulation shows a 27db improvement in PSRR (20 times), to 102db for the positive half. The simulator is usually accurate for the BC5xx/BC3x7 transistors, so I really think this is worth a try.
So is there a way you could test PSRR before and after?
Old 17th February 2014, 09:37 PM   #17
I have my build at Martina.
When i get it back i can try it.
I have an FFT analyser to ckeck PSRR.
Maybe i also build another one.
That has to wait until tomorrow.
Old 17th February 2014, 09:43 PM   #18
keantoken's Avatar
Great!
Old 17th February 2014, 09:45 PM   #19
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
With Joachim and Marina's approval of the early design coupled with the improvements you have in mind - it does appear that you have a very viable design. Congratulations.
I may well try a PtP build as a switching + volume control. In the meanwhile I would like to see the initial PS design provided you feel like sharing.
Good luck.
Old 17th February 2014, 09:45 PM   #20
Zero D is offline Zero D  United Kingdom
@ keantoken
Re - The Kuartlotron
Hi, i've only had a little time to play with it, but so far in Sim
I found that with R1 = 60R - R5 = 2k THD was less than 0.001% @ 1kHz & 20kHz. Output load was tried @ 1k & 2k, so driving most next stages should be no problem !
Is R9 supposed to be 2700k = 2.7M or 270k ? Anyway i tried both & didn't see a difference !
Great work
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
