Balanced ladder attenuator, make before brake question
Old 22nd January 2014, 06:24 PM   #1
2wice is offline 2wice  South Africa
Default Balanced ladder attenuator, make before brake question
What happens when an attenuator gets stuck on make before brake?
Old 23rd January 2014, 10:57 AM   #2
DF96 is online now DF96  England
You always get the same volume?
Old 23rd January 2014, 11:06 AM   #3
mcandmar is offline mcandmar
In theory you end up with the two resistors positions in parallel.
Old 23rd January 2014, 11:31 AM   #4
Thanks mcandmar,
What would that do to the output, I'm designing an attenuator but cannot guarantee that it will stop exactly on one resistor pad, it's not indented.
It might span 2 pads.
Old 23rd January 2014, 12:27 PM   #5
R.I.P.
as you sweep through the steps the attenuation will increase as you engage two pads of the adjacent steps and return to normal attenuation when only one pad of the step engages.
You can calculate the attenuation of the two steps and the attenuation of the combined effect of the dual pad step.
regards Andrew T.
Old 23rd January 2014, 12:39 PM   #6
Thanks Andrew
I'll have to try and indent it then.
Old 31st January 2014, 11:06 AM   #7
If make-before-brake(m-b-b) increases attenuation even for a moment, would there be a positive outcome if only the signal wiper or ground wiper was m-b-b? And which one would it be? The ground I assume?
Old 31st January 2014, 12:04 PM   #8
R.I.P.
It is not usual to switch the Signal Return line.
If you want to switch both Signal Flow and Signal Return, then your switch needs twice as many poles.
regards Andrew T.
Old 31st January 2014, 02:30 PM   #9
I'm trying to implement something like the attached.
I have a "wiper" that connects Rin with Rg, by changing the size of the wiper or or pad connected to Rin/Rg or changing the alignment of the pads, I should be able to get Rin or Rg or both to be m-b-b.
My thoughts are that the possible better options would be for both to be m-b-b but for Rg to happen slightly before Rin, or just Rg to be m-b-b.
Old 17th February 2014, 06:55 PM   #10
I'm tinkering with this design in my head and would like some assistance please.
In the attached, the signal in and ground planes are solid plated copper (1mm). Are there any benefits to doing it like this or is it better to have the signal in and ground out as traces on FR4 in stead of a solid plane? Click the image to open in full size.
Balanced ladder attenuator, make before brake questionHide this!Advertise here!
brake before make? RS 317-651 Kjeldsen Parts 2 24th October 2012 06:35 AM
HELP with DIY ladder attenuator !!!!! mcgreg66 Parts 1 4th July 2011 11:45 AM
Blanced stereo step attenuator ladder type question! bbakota2000 Parts 11 10th June 2004 06:51 AM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 11:00 AM
