Go Back   Home > Forums > Source & Line > Analog Line Level
Old 19th January 2014, 01:22 PM   #1
Default Single to differential into amp - transformer or dual opamp
My amp has a single to differential input into a class D tas5613. I am not sure of the input impedance of the tas5613, probably somewhere around 10k-50k (datasheet has a 10uf input cap on the differential input)
The differential circuit uses a traditional bridge stage with a quad opamp
(refer to fig. 21 : http://www.tij.co.jp/jp/lit/an/sloa064/sloa064.pdf )
I wonder if there are better circuits using opamp (discrete will probably be too much for me) or will I get improvement if I go with a buffer and a reasonably good transformer (I have a Tamura 600:600 on hand).
Else I will just duplicate the existing circuit using 4 LME49710 metal can.
TIA.
Old 20th January 2014, 10:14 AM   #2
thatcorp.com will have good solutions.
Gajanan Phadte
Old 20th January 2014, 11:37 AM   #3
Send a message via Skype™ to JonSnell Electronic
I would use a TL072, dual low noise op amp. Most manufacturers of quality analogue equipment use them, or equivalent. They will drive down to a 100R load.
www.flyingmole.co.uk For World Wide support for Flying Mole, Class D, Refurbishment and Repairs. www.jonsnell.co.uk
Old 21st January 2014, 06:24 AM   #4
I don't think I can source anything from "That" here in small quantities. I can use the single to differential opa1632. Does anyone have opinion on the opa1632 vs 4 opamps?
From the many reviews, I believe the lme49710/49720 is better than the TL072.
So no opinions on the use of transformers?
Old 21st January 2014, 06:30 AM   #5
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Transformers will probably beat opamps on subjective SQ. They have much better CMRR, have virtually no restriction on CM voltage (insulation breakdown isn't normally an issue) and no susceptibility to RF demodulation like active circuits.
The great audio capacitor myth : 'There's such a thing as too many PSU caps'.
Old 21st January 2014, 07:20 AM   #6
Did it Himself
richie00boy's Avatar
A TL072 is probably what's already in there, it's hardly an upgrade.
Also, they will start distorting once they have heavier than 2k ohms to drive.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more.
Old 21st January 2014, 07:38 AM   #7
jcx is offline jcx  United States
You can measure TL07x output distortion rising with "heavy" load even over 2K - the output stage is really poor - especially the negative swing
I have seen it burst into oscillation on negative V excursions with the Cload of < 10 ft cable
for audio line out you can use few 100 Ohm series load isolation so at least the oscillation may not bite you
purpose designed Instrumentation Op Amps have quite adequate CMRR for home audio
a downside of the best high isolation doubly shielded audio input Xfmr is "poor" bandwidth - practically good enough but not going to impress the audio gurus who call for 200 kHz minimum in all the rest of their electronics
Old 21st January 2014, 09:01 AM   #8
Ok, thanks. Guess I will try it. Currently I have the RCA input to a 25k pot, cap, and quad opamp.
For the transformer, after the pot, I assume a buffer is required?
Old 21st January 2014, 09:07 AM   #9
No, it is a quad opamp opa4228, it is already one of TI premium opamp. And it actually sounds fairly good. I just want to know if I can further improvement.
From some of the opamp comparison (and my experience), the TL072 actually ranks fairly low in audio quality. It is one of those opamp I will pull out when I see it.
Old 21st January 2014, 10:07 AM   #10
abraxalito's Avatar
I don't know how much voltage swing your trafo can handle (limited at the LF end usually by core saturation) but the TAS has only 21dB gain so probably you will want some more voltage gain after the pot.
how to connect two single opamp into dual? cent88 Construction Tips 9 20th January 2011 02:26 AM
Single or dual differential? lumanauw Solid State 346 29th November 2007 01:37 AM
Single or Dual opamp package? JojoD818 Solid State 15 19th December 2003 02:09 PM
JRC 45580 opamp..dual or single?? tone Digital Source 3 30th April 2003 05:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
