RIAA Pacific rookie attempt
Old 8th January 2014, 07:25 PM   #1
RobFreak is offline RobFreak  Denmark
Default RIAA Pacific rookie attempt
Hi everyone,
My RIAA literally went to smoke, so my 1210 is just staring in the wall doing nothing, i thought this was the best excuse to make an attempt on building the RIAA Pacific.
I have made a very quick drawing in EAGLE based on the Boozehound JFET Phono Preamp, which i would like to receive some comments on, please be aware that this is my first serious audio circuit. :-)
Caps:
C2, C7, C3 = MKP1837
C6 = RIFA PHE427
C4 = WIMA FKP2
C10, C9 = Nichicon Muse KZ
Schematic:
Board:
Old 8th January 2014, 07:54 PM   #2
dine1967 is offline dine1967  United States
Boozhound Laboratories: JFET Phono Preamp Kit
This is a bit modified version and works very well. I have assembled it on a veroboard and it sounds great.
Old 8th January 2014, 07:56 PM   #3
I was very close to buying that kit, but i wanted to do my own attempt. Only thing that bothers me are the Russian caps that are slightly expensive. Could MCap not be a replacement? I made an update to my schematic. :-)
Old 9th January 2014, 07:48 AM   #4
I made a clone, although without the Russian caps.
Old 9th January 2014, 02:34 PM   #5
Caps are a touchy subject here and everyone has their opinions. If you think you can hear difference then use whatever you feel are the best. I have used 2% and 5% WIMA caps and its good enough for me.
Old 9th January 2014, 02:39 PM   #6
Touchy and religious. I have updated my post with the caps.
Old 9th January 2014, 05:43 PM   #7
And a update schematic/board.
Old 9th January 2014, 06:41 PM   #8
Hikari1 is offline Hikari1  United States
I have the Boozehound kit, and built it first w/the Russian PIO caps.
I now have a sliver mica at c4, Jantzen silver at the output, REL polystyrene at C7, Vishay 1837 at c2 and a wima at c3. The sound is much more open and aggressive. To me, the Russian PIO caps are rolled off and soft but some may find that appealing.
If I was upgrading/replacing just one cap it would be the output cap and/or the interstage coupling cap.
Also, I am running 16 AA batteries which works well but I'd like to investigate regulated power supplies in the future...batteries are kind of a pain.
Old 9th January 2014, 06:47 PM   #9
Have you tried any other than the Jantzen silver on the output? I see they go for 15€ from Germany and a bit higher in Denmark, even though they are made here.. Id love to hear more about that, are you thinking in terms of noise filtering a AC-DC converter output?
Old 9th January 2014, 06:54 PM   #10
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
I built the same preamp using my own layout. It's one of the best-sounding phono preamps I've ever owned. This is a photo of the preamp circuitboard. It's mounted in an aluminum enclosure.
Frank
RIAA Pacific rookie attemptHide this!Advertise here!
Le Pacific RIAA preamplifier Bellus Solid State 3 10th August 2016 06:03 AM
Pacific Riaa codge Analogue Source 5 4th November 2010 11:53 AM
Need help with power supply for Pacific RIAA Dmeister Analogue Source 11 10th September 2010 10:58 AM
Riaa Pacific Jfet maxpou Analogue Source 23 15th April 2006 05:51 PM
RIAA Pacific deluxe from Elektor peranders Analogue Source 4 26th February 2004 03:52 PM
