LME49720 preamp for F5 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th December 2013, 10:07 AM   #1
Default LME49720 preamp for F5
hi
i start to bouild the F5 amplifier by nelson. the input impedance of the amp is 100K and the gain is 15db, so i feel that is need preamp.
my audio surce is sound card so in the output it have ~400mv.
i want to bay this preamp(the LME49720 is very quality specsification)
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
do you think its 20db gain is enough ? maybe i need less gain?
thanks
Old 26th December 2013, 10:21 AM   #2
read
What is Gain Structure?
regards Andrew T.
Old 26th December 2013, 10:54 AM   #3
thanks, its good article.
now im sure that if i want 25w on the F5 output, i have to amplified the computer signal.
but how much? i thins 20 db its ok, im worng? 0.3v *30 (F5)=9=>10W
so what i need is 0.8v in the entrance of the F5 to get 25w on the speaker !?
if so, the preamp in need to amplified by ~2 ! ?
i just want to be sure before i buy this preamp
thanks
Old 26th December 2013, 11:32 AM   #4
hates ground loops
Rodeodave's Avatar
With the F5's voltage gain of 15.3dB=20*log(x) and a maximum output voltage of +/-20V (from manual), the amplification factor x=10^(15.3/20)=5.82 and therefore the input voltage required to drive it to full output should be 20V/5.82=3.42V. Compare this to what your source can deliver, and decide on how much gain you'll need in the preamp stage.
Gravity - Making the G since 13.7 billion B.C.
Old 26th December 2013, 02:51 PM   #5
oppsss mistake i use this equation: db=10^(n/10). and 10log(x). sorry.
thanks for the info: i gain the audio source to follow ~3.4v
thanks
Preamp ideas for F5 ejfud Pass Labs 423 30th December 2013 06:13 PM
F5 needs a preamp for vinyl? Hikari1 Pass Labs 20 5th June 2013 09:23 PM
Juma's Preamp for F5 -new built- GentryBa Pass Labs 31 2nd February 2013 12:19 PM
Preamp in F5 manual Beftus Pass Labs 2 20th November 2009 07:10 PM
Heat Dissapation Problem LME49720/OPA1632 Preamp artquake Chip Amps 45 2nd June 2008 06:53 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
