DBX Active Crossover - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th December 2013, 01:55 AM   #1
Default DBX Active Crossover
I have a pair of Mark Audio A12s, I want to add a set of mid-bass modules in a ported enclosure. That is all well and good but I don't want to lose my 100% analog signal path. Is the dvx or similar active crossover a good approach to go?
Any recommendations?
Old 18th December 2013, 02:47 AM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Marchand make a passive line-level crossover. That's likely to be more transparent than an active XO. You'd need a decent drive capability for it though as it presents about 1kohm impedance.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 18th December 2013, 03:15 AM   #3
not if you don't want to lose your 100 % analog signal path.
besides the dbx driverack(system controller) is a line level device (as in ahead of amp) or is bi or tri-amping something you want to try?
Old 18th December 2013, 12:07 PM   #4
Bi-Amp: Yes, I want to pull the low frequency workload off of my primary amp which only has 4 watts. It is a Decware Mini Torii.
So essentially the Mini Torii would power the Mark Audios from 150 up and then a different power amp to power the woofers.
I was thinking of these: Dayton Audio RS180-4 7" Reference Woofer 4 Ohm | 295-374
The woofers would be in a 1.33 ft.3 rear ported enclosure and should reach 35 @ -3 dB. They have a very smooth curve and it should and remain flat.
Then the Marks would be moved out of the Super Pensils to an 8 liter sealed enclosure which will hit 100 Hz @ -3 dB.
Essentially I imagine these looking as if they are a single cabinet but in reality they are two separate enclosures. The reason for the XO is because I want to be able to adjust the setup and relieve the tube amp from the low freq duties. The main reason for this is a XO would rob what little power I have going to the speakers.
Currently looking at this Active XO: Ashly XR1001 | Sweetwater.com
Old 18th December 2013, 12:46 PM   #5
what sort of amp are you thinking for the sub?
Old 18th December 2013, 08:41 PM   #6
I am open to options for the amp to power the woofers, ideally something clean and powerful but my Mini Torii is doing most of the heavy lifting and providing most of the voice characteristics of the frequency range.
I just need the bass extension. I am not listening to hard rock or anything crazy here just some Jazz, Blues, and occasional Van Morrison/Neil Young etc.
I was thinking about the Dayton APA150 or similar, 75 WPC @ 4 ohms.
Old 18th December 2013, 08:42 PM   #7
Side Note: The Mini Torii can function just fine with 2V input or even lower... it is designed to have gain to handle even something like an iPod without issue. The XO shouldn't cause too much of an issue I don't think.
Old 18th December 2013, 09:31 PM   #8
the Mini Torii doesn't seem to have balanced inputs so wiring in a dbx driverack on both the input and output side is gonna mean some cable building.
what are you using for source switching?
Old 18th December 2013, 09:44 PM   #9
frugal-phile(tm)
planet10's Avatar
I figure it is always worthwhile to see if a PLLXO can work. They are limited, but the simpliest can be 4 small caps & 2 Rs (and level control on at least one amp -- the one that needs to be turned down, usually the woofer amp)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th December 2013, 10:42 PM   #10
that would certainly work and fill the"keeping it" analogue criteria!
not to mention alot cheaper than a driverack!
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
dBX 223XL vs Behringer CX3400 active XO? grantnsw Multi-Way 29 25th June 2012 08:00 PM
DBX 234 active crossover, LNIB architect7 Swap Meet 2 17th January 2012 06:45 AM
FS: DBX 223 Stereo 2-Way/Mono 3-Way active crossover ghg Swap Meet 0 6th December 2011 08:36 AM
FS: Two DBX 234 3-way active crossovers CharlieLaub Swap Meet 2 10th April 2010 05:48 AM
Copyright 1999-2017 diyAudio
