DBX Active Crossover - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th December 2013, 11:17 PM   #11
Originally Posted by turk 182 View Post
the Mini Torii doesn't seem to have balanced inputs so wiring in a dbx driverack on both the input and output side is gonna mean some cable building.
what are you using for source switching?
The MT has two inputs, it is a pre-amp and power amp setup as dual mono blocks.
You are correct, no balanced inputs, just single ended RCA jacks.
I was thinking of this cabling...
Turntable -> Pre-Amp -> XO >100 HZ -> MT -> A12p
-> XO <100 HZ -> ?AMP -> Woofers
Is that an improper assumption?
Old 18th December 2013, 11:23 PM   #12
that signal chain description seems correct.
Old 18th December 2013, 11:25 PM   #13
The easier option is to use the pre-outs on my Mini Torii and just send that to powered woofers or woofers that have a passive XO.
Pros: Much Simpler, Cheaper
Cons: Still sending 100% of the signal to the Mark Audio A12s
Thoughts on the two options?
Old 18th December 2013, 11:49 PM   #14
well my answer is tainted by the fact as an old pa guy i have a bunch of tuneable 2 and 3 way x-overs kicking around and it's not out my capability to build an active x-over.
speaking of which how familiar are you with mini dsp that might be the ticket for what your thinking of.
Old 18th December 2013, 11:54 PM   #15
My brother has a miniDSP 2x4 and I have tried it, it unsurprisingly pulls all the emotion and soul out of the signal (IMHO). > Hence why I am kind of dead set on staying analog, ideally crossover-less to eliminate phasing issues etc.
Overkill? Maybe.
Old 19th December 2013, 12:11 AM   #16
well you learn something new everyday
Old 21st February 2014, 01:31 PM   #17
Dmatuszak's Avatar
If anyone is still following this thread I am looking for some advice on pro audio analog crossovers. Specifically, I was wondering if anyone here has looked inside any of the commercially available pro audio crossovers and can comment on the quality of components and powersupply. I have been using a 2x 4th order LR that I built 20 years ago and am looking to go to a 3x. Before building another unit I though I would take a look at commercially available units but don't want something that is inferior to what I have been using in terms of quality.
Active Crossover: Behringer x DBX active DriveRack 260 murillollirum Multi-Way 21 9th February 2013 07:12 AM
dBX 223XL vs Behringer CX3400 active XO? grantnsw Multi-Way 29 25th June 2012 08:00 PM
DBX 234 active crossover, LNIB architect7 Swap Meet 2 17th January 2012 06:45 AM
FS: DBX 223 Stereo 2-Way/Mono 3-Way active crossover ghg Swap Meet 0 6th December 2011 08:36 AM
FS: Two DBX 234 3-way active crossovers CharlieLaub Swap Meet 2 10th April 2010 05:48 AM
Copyright 1999-2017 diyAudio
