Single ended to balanced conversion
Old 28th October 2013, 10:30 PM   #21
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
toucheŽ
Originally Posted by pooge View Post
There is no "signal ground" in a balanced system.
but if you use connectors for the simple SE to balanced convertion there will be a signal ground connected, no ?
he stricly said he would not consider trafos due to budget
that said ...
RCA connectors are always isolated from chassis, and for a good reason, right ?
and besides, XLR also happens to have a 4th 'pin' for chassis connection, and also for a good reason, right ?
sometimes we know very little, and sometimes we know too much
Old 30th October 2013, 12:46 AM   #22
Speedskater is offline Speedskater  United States
Speedskater's Avatar
The Hot connects to the '+' input
The Return/Shield connects to the '-' input.
that said ...
While we still have a large number of retro members. The RCA shell/shield does connect to the chassis.
It took 20 years to get the XLR thing correct, it will take another for the RCA connector.
Well No.
The XLR connector tab/shell is no longer connected in balanced cables. (although it may be connected in chassis connectors)
It's all about what is called the pin #1 problem (even if the connector is numbered differently)
Jim Brown discusses the problem in several papers.
Audio Systems Group, Inc. Publications
Kevin
Old 30th October 2013, 01:10 AM   #23
benb is offline benb  United States
Sound System Interconnection
Old 21st February 2016, 02:00 PM   #24
noSmoking is offline noSmoking  United States
noSmoking's Avatar
Default good read
Originally Posted by benb View Post
Hi benb,
Thanks for that,good to keep for a ref!
NS
Old 22nd February 2016, 10:37 AM   #25
Worth reading an003 as well.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd February 2016, 02:22 PM   #26
noSmoking's Avatar
HI Andrew,
I need a Volume control for a balanced circuit,it's input will source from AK4393.
On the data sheet it recommends going from bal to SE and putting a pot there and reconverting back to bal to enter the bal amps ,In your opinion is this the best way to get a volume control in a balanced system?
Would a bal B1 do the job? I was considering it and use a switched att with matched smd's to over come mismatch of a ganged pot?
I have read about 2 v is output of AK4393 and that is enough to drive my amps,My system is bal 4 way, 2 bal F5 for highs,2 alph J's for mids,2 aleph's for bass and 2 550Wchip amps to drive 2 Xoc1's 18subs ,I have 2 Ba3's to replace those almost finished to replace chip amps.
Thanks for the links,I'll read it now.....
Thanks,
NS
Last edited by noSmoking; 22nd February 2016 at 02:30 PM. Reason: more thinking,lol
Old 22nd February 2016, 05:01 PM   #27
Originally Posted by noSmoking View Post
HI Andrew,
Don't bother with my opinion. Read Bruno Putzeys' article and the Thread discussing this method.
A B1 would be nearly impossible to keep balanced. Again, read Putzeys.
The F5 was never designed to be balanced. Read the F5x, or the balanced version of the F5t
Thanks,
NS
regards Andrew T.
Old 22nd February 2016, 11:07 PM   #28
noSmoking's Avatar
Thanks for your reply !
Have a GREAT day!
NS
Single ended to balanced conversionHide this!Advertise here!
The XCEN -- Balanced to Single Ended Converter EUVL Analog Line Level 117 18th March 2014 11:56 PM
Tube conversion of differential to single ended signal audiowize Tubes / Valves 5 8th August 2013 08:19 PM
Single Ended to balanced for F4 Joshua_G Pass Labs 10 24th April 2011 10:57 PM
Converting single ended amp to balanced boyelroy Solid State 15 10th November 2002 04:51 PM
Does it Make Sense? Balanced to Single Ended Super_BQ Pass Labs 3 3rd October 2002 09:01 AM
Copyright ©1999-2017 diyAudio
