4 chanel Stereo Input Selector - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th October 2013, 06:16 AM   #1
Banned
Default 4 chanel Stereo Input Selector
I have completed 4 channel Audio controller circuits,
brain of this kit is 89C52 based controller board, which is programmed for LCD interface, front panel with button and LED's
it supports PSU interface, Standby and Active mode.
after power on it goes to "Standby" mode, on press on button it goes into "Active" mode & prompts for channel selection, upon press of button it changes channel, same is displayed in LCD.
Active and Standby mode signals PSU, high and low .
Front panel button and LED:
Two buttons for Power on an other for Channel Select.
Two LED , Power on off LED and Button press response LED with option for buzzer (5 volts beeper) on board.
Image Description:
Image 1 (SEL_Standby2.jpg) : After Power ON, Standby mode.
Image2 (SEL_Select2.jpg_ : After press on button, Active , Select (prompt for channel Select)
Image 3 (SEL_Channel1.jpg) : After pressing Channel Select Button. Shows "Channel 1"
Thank you
Sudheer
Old 17th October 2013, 09:31 AM   #2
bimo is offline bimo  Indonesia
bimo's Avatar
Do you use relay or IC for select the analog input?
About 15 years ago, I use 89C52 (8051 family), after that I use AVR microcontroller and PIC. But PIC is expensive here.
3 Chanel analogue input class d chip hamedfazelm Class D 0 30th July 2010 02:46 PM
Recommendation and source for rotary stereo selector quietdragon Parts 7 1st June 2010 09:59 PM
Input selector Simo88 Everything Else 25 15th July 2009 01:33 AM
Stereo source selector IC speakerguy79 Parts 4 29th November 2008 01:16 AM
Copyright 1999-2017 diyAudio
