600:10k line stage transformers any use? - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th October 2013, 11:50 AM   #1
Default 600:10k line stage transformers any use?
A musician friend of mine gave me a handful of these transformers:
Altronics - M0705 600 Ohm : 10k Ohm Shielded Microphone Transformer
The wiring diagram is here:
http://www.altronics.com.au/download...eets/M0705.pdf
What kind of purpose would these serve for home/diy audio?
Old 4th October 2013, 11:53 AM   #2
TonyTecson's Avatar
line amp with XLR output....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 4th October 2013, 12:04 PM   #3
Thanks. I have a preamp with an XLR output, also a dac which has a passive I/V stage, so the transformers might be of some use.
The 'datasheet' has so little detail! What is this transformer actually doing (besides impedance matching)? Is there any gain provided?
Old 4th October 2013, 12:11 PM   #4
TonyTecson's Avatar
if you use the 600 ohm side as input, then you have gain....
you can try to use that for an MC step-up transformer....
Old 4th October 2013, 12:29 PM   #5
Ok great, how do we calculate the gain?
For example, my balanced dac puts out 1ma per channel, with 10R iv resistors we get: 10 x 0.001 = 0.01vrms. Tiny!
At the moment I run this into a 30db gain tube amp, which drives a push pull power amp (100k input impedance) quite well.
Could these transformers be used to replace the line stage tube pre?
Old 4th October 2013, 12:52 PM   #6
john65b is offline john65b  United States
john65b's Avatar
Front end Phase splitter for tube amp? Isn't this like a Lundahl LL1690? Like what would be used for the Pete Millet Universal Driver board?
Heck, if so, I may want a pair for a couple experiments....too bad I am across teh pond.
Thinking of using the Edcor 600/10k or 10k/10k transformers too...
I Speak Spanish to God, Italian to Women, French to Men, and German to My Horse. Charles V
Old 4th October 2013, 01:52 PM   #7
I have a few lundahl trannies (not for the same purpose), so should be in a position to give a good comparison on the sound signature.....if I can find a good use for these units!!
Out of interest, how would one wire up an unbalanced input and output to these trannies?
Old 4th October 2013, 05:25 PM   #8
Sqrt(10000/600) is about 4. These are input transformers, not enough size for output.
Old 5th October 2013, 12:08 AM   #9
TonyTecson's Avatar
there are other reasons for using the traffo aside from gain..
galvanic isolation can be useful in eliminating ground loops...
Old 5th October 2013, 01:53 AM   #10
Ok well I'll test it out on an old linestage and see how they sound. Whhat would the wiring be for an unbalanced input/output?
600:600 ohm output transformers for v-out DAC - $40 for 2 wireswithgain Swap Meet 11 5th November 2013 10:53 AM
FS: LM49710/LM49600 Amp (The Wire-ish) and +-15v Bipolar supply, 600:600 Transformers wireswithgain Swap Meet 13 14th August 2013 02:54 PM
FS cinemag transformers nickel CMOQ-2H 600:600 Gluca Swap Meet 10 6th March 2013 06:01 PM
FS/Trade Hammond 850G 150/600:150/600 Line Isolation/Hybrid Matching Transformers VictoriaGuy Swap Meet 0 3rd August 2011 09:29 PM
EDCOR XSM 10K/10K Transformers wushuliu Swap Meet 3 15th January 2011 07:24 PM
Copyright 1999-2017 diyAudio
