Adding in RCA Outputs - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th September 2013, 01:24 AM   #1
Default Adding in RCA Outputs
Hey Everyone.. first post and I am *really* not sure if I am even posting this in the right area. If not, moderators can you move it to where it *should* be?
I am not sure if I can attach pictures or not, so I will describe it the best I can. When my father-in-law passed away, my mother-in-law gave us his new (but made to look like an old radio) the one with a CD drive and AM/FM radio, Turn Table etc.
What I want to do, is put some red/white RCA jacks on the back so I can output it to my Onkyo Amp so I can spin some vinyl and listen outside near the pool via Zone 2 or what not.
I have looked around and really, the question is, what do I cut/splice to out put what is heading to the built in speakers to the Red and White respectively from each speaker?
Well, I hope I can figure this out. I have electronic experience as an Avionics Technician, so soldering isn't an issue, I just need to know what to do.
Thanks.. let me try to attch the pics.
Old 7th September 2013, 01:34 AM   #2
just another
wintermute's Avatar
Hi And welcome to diyAudio. I've moved to Analog Line level as that seems to be the best spot. Note that you do not want to take speaker level output for your rca's it needs to be line level before the main amplifier. Any details on the internals would be helpful
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 7th September 2013, 01:49 AM   #3
Thanks Tony,
I have not 'cracked the case' yet, but if it would help forum members, I can. Now this just got tough pre-amplifier.. I was hoping for yeah, snip the wires going to the speaker and solder them to some wire then to the posts of the RCA output jacks.. bummer..
Joe
Old 7th September 2013, 03:38 AM   #4
mattmcl is offline mattmcl  United States
You could use something like this. I wouldn't call id audiophile grade but it will get the job done.
Amazon.com: Speaker RCA Line Level Converter Adaptor High Low Hi Lo with Gain Control Add: Computers & Accessories
Old 7th September 2013, 09:55 AM   #5
DF96 is offline DF96  England
Use Google to find a circuit diagram. There will almost certainly be somewhere in the circuit where you can pick off a line level signal, but without a diagram you are working in the dark.
PS the thread title should be RCA outputs, not inputs
Old 7th September 2013, 12:07 PM   #6
just another
wintermute's Avatar
^ good point I changed the title
Some of my photos
Old 7th September 2013, 12:24 PM   #7
Does the unit have a headphone jack? If so, just feed that to the amp.
Adding line level outputs to an amp peace brainerd Solid State 5 7th January 2013 12:45 AM
Two RCA Outputs into One! HOW TO!? ltjenkem Analog Line Level 5 17th September 2011 08:25 AM
Multichannel DAC with 5+ RCA outputs Aetherion Digital Source 8 17th July 2006 04:53 AM
Adding balanced outputs to SqueezeBox ezkcdude Digital Source 1 21st March 2006 02:12 AM
Adding preamp outputs to factory radio ECM Car Audio 18 1st September 2004 10:42 PM
Copyright 1999-2017 diyAudio
