Bonsai's practical buffer - Page 12 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th September 2013, 07:37 AM   #111
Bonsai is online now Bonsai  Europe
Bonsai's Avatar
Here is a 1-2-1 picture next to the Alps pot
bonsai
Amplifier Design and Construction for MUSIC! http://hifisonix.com/
Old 27th September 2013, 02:18 PM   #112
Would it be possible to use BF244A for this buffer or it must be BF244B orC?
Old 17th June 2014, 05:11 AM   #113
Hi Bonsai
Did this get anywhere?
Old 17th June 2014, 10:59 AM   #114
Bonsai's Avatar
The PCB is designed and the article has been written.
But Inhave not ordered the PCBs yet.
I need to order some for another project shortly, then I will order some boards, build and test.
Note: it's SMD
bonsai
Old 17th June 2014, 11:18 AM   #115
thimios is offline thimios  Greece
Note: it's SMD
Is this (post#100)the final pcb under test?
Thimios.
Old 17th June 2014, 11:44 AM   #116
Note: it's SMD
Excellent...
Old 17th June 2014, 02:19 PM   #117
Bonsai's Avatar
Thimios.
Yes
bonsai
Old 6th January 2015, 06:27 PM   #118
Any progress about this?
Old 6th January 2015, 10:17 PM   #119
QUOTE=Bonsai;3963865]...
Note: it's SMD[/QUOTE]
Mmmm, looks like mostly 805, I can handle that. Just no 603! Those ssip me off!
Old 7th January 2015, 03:09 AM   #120
Bonsai's Avatar
I did complete the layout but never built it so was reluctant to publish the board in case there were errors.
I can later today attach the write-up.
I am moving now so digging the layout up will have to wait.
The smallest SMD size was 1206. These are very easy to put down but YOU MUST USE A FINE TIP SOLDERING IRON, 0.8 mm solder and a pair of fine tipped tweezers
bonsai
"Bonsai" decorative Ipod system spudfrog Full Range 42 16th April 2010 08:44 PM
Is this practical tenderland Tubes / Valves 10 1st April 2006 01:56 AM
a few practical questions... hugobross Solid State 17 6th September 2002 10:26 AM
Copyright 1999-2017 diyAudio
