Diamond Cascode, a Diamond-like buffer/current booster
Old 16th August 2013, 11:22 PM   #11
bear is offline bear
expert in tautology
bear's Avatar
well there is a benefit to the circuit if it ads nil harmonics to the basic opamp and manages to boost the current!
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 16th August 2013, 11:35 PM   #12
Struth is offline Struth  Canada
Banned
Hi Guys
That's essentially my point. The EF is just one stage - not a diamond - so it does give the benefit of current boosting. An open-loop single-ended EF produces mostly 2nd harmonic THD. One would expect some canceling of evens with a push-pull EF but this is not always the case. So, there may in fact be some harmonic enhancement with the EF on its own basis.
How did a brown bear get to the east coast? We only have black bears around here.
Have fun
Kevin O'Connor
Old 17th August 2013, 11:03 AM   #13
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
FWIW, I added the base-to-base capacitor for the EFs and redid the layout, squeezing it in the same area as before - however, only a 0603 will fit for now, which is fine for small X7Rs. There's an added bonus - a zero-ohm resistor can be optionally fitted there to allow modifying the assembly (with the nJFET CCS installed, but the rest of the discretes omitted) for opamp + CCS Class-A operation alone.
Old 18th August 2013, 03:03 AM   #14
clarkynoel is offline clarkynoel  Indonesia
Originally Posted by linuxguru View Post
Thanks - I haven't specifically measured the DC offset, except at the output of a MyRef Rev C with an LM318M installed as U1. In that case, it was negligible - 0.6 and 1.4 mV respectively in the two channels at the main speaker output.
The existing prototypes use LM318M (~6 qty) and LME49990 (1st unit assembled this morning, tested working - will do another one and audition shortly).
Hi Siva, may I know what do you expected with your prototype installed as 'LM318' in MyRef Rev C?
Does it give better sound?
Old 18th August 2013, 05:10 AM   #15
I certainly prefer it to the plain LM318 for the kind of music I listen to - the audible sonics of the LF07 are distinctly Class-A in a MyRef Rev C: better definition, resolution, micro-detail, air, smoothness, etc.
However, for the differences to be audible, the other components in the MyRef also have to be of sufficiently high quality - C13, C9, C12, C7, R12, C10, C32, C30, C34, C6, C11, etc. have an impact on sound quality in a MyRef.
Old 18th August 2013, 06:05 PM   #16
expert in tautology
bear's Avatar
So have you tried the newer "super-ultra low distortion" opamps at all?
_-_-bear
Old 18th August 2013, 08:15 PM   #17
I've tried the LME49990, which works - but it needs a reference DAC/CD player to be able to tell the audible difference with and without the buffer. Perhaps a better test would be in a CMoy, driving low-Z headphones.
Old 19th August 2013, 03:45 PM   #18
expert in tautology
bear's Avatar
Have you compared it to the Chris Paul/Bob Cordell cross coupled output buffer? (Cordell uses that connection, but Chris Paul published it I think earlier... still trying to get to the bottom of that... like where that circuit came from)
_-_-
_-_-bear
Old 20th August 2013, 03:26 PM   #19
Is there a link that shows or discusses this topology? Bob has posted a lot of stuff here, so it's daunting to wade through a zillion posts.
Meanwhile, the base-to-base capacitor for the EFs suggested by Kevin does not appear to hurt audible sonics, and it sims with lower H2 and THD20 as I mentioned earlier. I kludged a 100nF Panasonic ECHU stacked PPS film cap into a couple of LF07 modules and auditioned them in a MyRef Rev C. The sonics are the same as before, except that the definition and resolution of the highs seem enhanced. I'll listen to it for a while, but it already looks like a worthwhile enhancement.
Old 20th August 2013, 04:42 PM   #20
expert in tautology
bear's Avatar
Yeah... ummm... it's used in the output stage of his power amps, iirc... in his book. I mentioned it some years ago in a thread about output buffers, and suggested the connection instead of having the drivers collectors going to the rails, go to the junction of the output's emitter + emitter resistors on the opposite side.
So instead of going to the + rail, the lower driving transistor would connect to junction of the output run off the + rail and its emitter resistor...
dunno if that makes any sense...
I'll try to find an example I can link or upload.
_-_-bear
Diamond Cascode, a Diamond-like buffer/current boosterHide this!Advertise here!
Current feedback high speed headphone amp with diamond output buffer peranders Headphone Systems 106 20th August 2015 02:51 PM
Jfet folded cascode with diamond buffer opamp sonnya Analog Line Level 35 28th April 2013 01:34 PM
Diamond buffer pdul Solid State 23 5th February 2012 04:06 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 06:58 AM
Diamond buffer peranders Solid State 45 16th November 2003 12:00 AM
