CS3318 PCB Layout
CS3318 PCB Layout
Old 9th August 2014, 01:53 PM   #121
dhalbakken is offline dhalbakken  Thailand
Unless someone can recommend a better DIY CS3318 design, I think I'm interested in building one of these. In message #63 Dr_EM wrote "there was a fatal error." Is the final PCB artwork and controller code for this unit posted somewhere?
Old 9th August 2014, 03:55 PM   #122
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
Hi dhalbakken, the final version has the error corrected and works fine when assembled as per the BOM, no modifications. I still have the 2 spare PCBs and attach the final artwork.
The only aspect I'm unsure about is the speed of control over SPI. I've now tried it with hardware SPI from a PIC microcontroller as well as bit-bang and I cannot deliver SPI faster than about a message every 50mS, only the slowest SPI setting (clocked by TMR2 module) works with any of the 4 available clock relations (CKE and CKP bits). I don't see how this can be a hardware/PCB issue and looking on the scope at signals arriving at CS3318 pins the clocks are perfectly defined, no overshoot/ringing, so I'm still stuck on this issue. Even stranger is that my DAC PCB uses the same control with the ADuM isolator and works flawlessly at all SPI rates.
Hopefully someone can shed some light on this so I'll attach the PIC code I'm using with a DIP PIC18F4520 on breadboard for now. This code configures the DAC and CS3318 then sends volume settings to it from a rotary encoder (Bourns optical type).
Code:
// PIC18F4520 Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1H
#pragma config OSC = INTIO67    // Oscillator Selection bits (Internal oscillator block, port function on RA6 and RA7)
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 3         // Brown Out Reset Voltage bits (Minimum setting)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = PORTC   // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF     // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = ON       // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF        // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-001FFFh) not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (002000-003FFFh) not code-protected)
#pragma config CP2 = OFF        // Code Protection bit (Block 2 (004000-005FFFh) not code-protected)
#pragma config CP3 = OFF        // Code Protection bit (Block 3 (006000-007FFFh) not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-001FFFh) not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (002000-003FFFh) not write-protected)
#pragma config WRT2 = OFF       // Write Protection bit (Block 2 (004000-005FFFh) not write-protected)
#pragma config WRT3 = OFF       // Write Protection bit (Block 3 (006000-007FFFh) not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot block (000000-0007FFh) not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-001FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (002000-003FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (004000-005FFFh) not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (006000-007FFFh) not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) not protected from table reads executed in other blocks)
#define _XTAL_FREQ 8000000
#define rotary_A PORTBbits.RB4
#define rotary_B PORTBbits.RB5
#define SPICS_DAC PORTCbits.RC1
#define SPICS_VOL PORTCbits.RC2
#define RESET PORTCbits.RC0
int encoderValue = 0b00111111;
unsigned char Volume = 0;
char OldOutput = 0;
void SPI_send (unsigned char data)
        SSPIF = 0;
            SSPBUF = data;
        while (SSPIF == 0);
        PORTD = data;
main ()
OSCCON = 0b01111110;
TRISA = 0b00000000;
TRISB = 0b00110000;
TRISC = 0b00000000;
TRISD = 0b00000000;
T2CON = 0b00000111;
SSPSTAT = 0b11000000; /*CKE = 1*/
SSPCON1 = 0b00100011; /*SPI Enabled, CKP = 0, SPI Master at TMR2/2*/
IPEN = 0;
INTCON = 0b11001000;
RESET = 0;
SPICS_DAC = 1;
SPICS_VOL = 1;
__delay_ms (80);
__delay_ms (80);
__delay_ms (80);
__delay_ms (80);
__delay_ms (80);
__delay_ms (80);
__delay_ms (80);
__delay_ms (80);
__delay_ms (80); /*Wait while supplies settle*/
RESET = 1;
__delay_ms (20); /*Wait for devices to come out of reset mode*/
SPICS_DAC = 0;
SPI_send (0b00100111); /*24-bit I2S configuration*/
SPI_send (0b00000001);
SPICS_DAC = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0x80);  /*Errata*/
SPI_send (0x00);
SPI_send (0x99);
SPICS_VOL = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0x1d);
SPI_send (0x86);
SPICS_VOL = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0x1f);
SPI_send (0x02);
SPICS_VOL = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0x0);
SPI_send (0x0);
SPICS_VOL = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0x80);  /*Device configuration*/
SPI_send (0xb);
SPI_send (0b00010000);
SPICS_VOL = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0xc);
SPI_send (0b00001110);
SPICS_VOL = 1;
__delay_us (100);
SPICS_VOL = 0;
SPI_send (0x80);  /*Master power*/
SPI_send (0xe);
SPI_send (0b00000000);
SPICS_VOL = 1;
__delay_us (100);
    while(1)
        Volume = encoderValue/2;
        if(Volume != OldOutput)
        SPICS_VOL = 0;
        SPI_send (0x80);
        SPI_send (0x11);
        SPI_send (Volume);
        SPICS_VOL = 1;
        OldOutput = Volume;
void interrupt ISR(void)
    if(RBIF)
			static int old;
	   		static int new;
	   		static int value;
	   		new=(rotary_A|(rotary_B<<1));
	   		value=((new<<1)^old);
	   		if (value & 0b00000010)
					if(encoderValue<511)
					encoderValue++;
		         	else
					if(encoderValue>0)
					encoderValue--;
	   	old=new;
		RBIF = 0;
Otherwise, I can confirm the analogue audio measures and sounds very good and is much more impressive than the PGA2310 which often seems to exhibit hiss in practise. This board is silent even with tiny input signals and all 22dB of gain
Old 9th August 2014, 11:29 PM   #123
Thank you, Dr_EM. Nice work.
I'm afraid I can't help with the SPI issue. If I do build this board, I most likely will adapt your code to the Arduino Uno, which I happen to have bouncing around in my junkbox.
Old 10th August 2014, 02:25 PM   #124
I'm just checking things over and creating a list of parts to buy. I think the unlabelled part on the schematic between the ADuM7440 and the (unlabelled) CS3318 is a TPS3823-33, right?
Old 10th August 2014, 02:41 PM   #125
Dr_EM's Avatar
Hi, yep that's the correct part. It should protect the CS3318 in the event that digital power is lost but analogue power remains by putting the CS3318 straight into reset mode. Otherwise the device can overheat as the analogue gain stage oscillates from loss of valid control signals.
PM me if you need a PCB. They were made through OSH Park, who I've used several times since and have always had great quality results. I also still have 2 of the CS3318 ICs if you need one, I know they can be hard to obtain
Old 11th August 2014, 07:58 AM   #126
Regarding the ADuM7440: I see there is a 1 Mbps part and a 25 Mbps part. I thought I'd order the 25 Mbps part. Did you use the 25Mbps part?
I am pricing it all out to compare to a resistor/relay based volume control. The highest priced items I've encountered so far in your design are the 8 film capacitors. Too bad the WIMA brand MKS4 (which are quite a bit less expensive here than the Kemet ones I'm looking at) won't quite fit. The WIMAs are 9 mm deep, and I think your board has 8.8 mm max depth for side-by-side capacitors. Do you think I could squeeze the WIMAs in?
Anyway, I'm not sure it's fair to include capacitors in my price comparison because the resistor/relay board would not provide dc blocking in the signal path.
Have you thought about what the hazards might be without DC blocking on the input? I am now using a DAC that does not have blocking on its output. It is driving a switch-based resistive stepped attenuator followed by a Borbely DC100 amp. I now have millivolts of DC on the power amp output, but maybe I'm living dangerously.
I've sent you a pm.
Old 11th August 2014, 07:46 PM   #127
Dr_EM's Avatar
Hi, I looked at my order invoice and I used the 1Mbps part. Either should work though, not certain if the 25Mbps part has faster rise/fall times, that's the only thing which may upset it. Most likely the 1Mbps is just as fast, only the isolation barrier is slower.
I attach an image of the capacitor package. The green line is 9mm long and you can see it extends slightly beyond the silk screen outline, but the caps aren't quite touching how they are located on the PCB. I reckon it'd be tight and ones toward the edges might not fit flush to the board, but if their leads are thin enough I expect they would all sit flat, it'd give just enough play.
DC blocking is important for a stepped volume controller like this (or a relay one) as you can get clicks during volume changes otherwise. The zero cross detector helps of course but it won't see a few mV of DC offset, however with high gain you could hear it as it shifts. A few mV of offset on the poweramp output is OK, over 50mV and I'd be concerned, but there's no reason it shouldn't be able to be kept below 2-3mV.
Old 12th August 2014, 01:42 PM   #128
Thanks, Mr Dr_EM.
I misread the WIMA datasheet. The dimensions I was looking at were for the 50v part. The 63V WIMA part should fit without problem.
Sorry for so many questions, but I have one more. I can spend more time trying to figure out a complete parts list, but I wonder if you have one already. If so, it would be helpful if you could post it.
In particular, in one of the messages in this thread you wrote, "0605 and 0805 SMD Capacitors." I'd prefer not to try to figure out from the images you posted which are 0605 and which are 0805 if this information is readily available from you. If not, I will do the work.
Thanks again.
Old 12th August 2014, 06:12 PM   #129
Dr_EM's Avatar
I'm surprised if the 63V part is physically smaller? That's good if it will fit though. I used the Arcotronics ones here, but they're currently out of stock:
R60DN51005030J - ARCOTRONICS - CAP, FILM, PET, 10UF, 63V, RAD | Farnell UK
Sent you an email with the BOM
Old 2nd October 2014, 07:40 AM   #130
I built the board, but so far I have been unable to get any audio through it. Soldering looks good. All voltages and SPI signals to the CS3318 look right when checked with an oscilloscope. I've tried various SPI signal delays, SPI library speeds, and so on, but with no luck.
Perhaps someone would be willing to review my Arduino Uno code. I've posted it at
https://gist.github.com/anonymous/9fbcb97cd83466f07da3
I hope I haven't fried the CS3318, but that's my only idea now. But I don't have a clue as to how I might have done that. I was pretty careful with the board.
CS3318 PCB LayoutHide this!Advertise here!
cs3318 and arduino linuxworks Analog Line Level 123 27th March 2017 08:32 AM
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
Digital Volume Contol - CS3318 - MAX5440 Ridin '24'z Digital Source 5 8th June 2011 01:36 PM
Who can do PCB layout d3imlay Solid State 3 23rd November 2007 11:55 PM
help for a PCB layout pencoat Parts 0 4th October 2006 01:52 AM
