Capacitors at 50v vs 25v on replacement in preamp power supply? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 23rd July 2013, 02:58 AM   #21
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
LOL back at ya, jean-paul. My handle is 25 years young, and I hope to see it to 30 years. Meanwhile, I battle the vapor-thin theories of snake-oil and magic charms. Brings out the best in people.
(PS: I use italics for posters' names, for titles of other articles, for bibliographic references, and for certain emphasis. jean-paul with the uncapitalized J seemd to need the italicization, by the first rule. Glad you like it... it takes extra time to type in.)
GoatGuy
Old 3rd September 2013, 02:47 PM   #22
Default Jean-Paul thoughts on PSU?
Originally Posted by jean-paul View Post
- 10 to 100 µF 25 V standard electrolytic caps at the outputs of the regs and definitely not larger (if you like the regs to behave well that is). Check 78XX datasheets and you will read why. The regs don't fry or something like that but they will not perform any better and they possibly even oscillate at a low frequency with very large caps.
This was on the PSU of a preamp with 1000uF 63v spec'd both before and after the 7815/7915. I've heard that the cap after the regulator "forms a 'snubber' or 'zobel' that opposes the inductive impedance rise the regulator displays." If one uses a cap like Elna Silmic that does not have ultra-low ESR, the larger cap value is desired after the regulator.
Jean-Paul, I don't really understand these things but thought I'd ask your thoughts on that.
Old 3rd September 2013, 03:15 PM   #23
Arguments about when and what aside, one other thing to consider is the anticipation of failures. It's always good to consider what happens if a reg shorts out or a load goes open. The fewer parts that fry, the better. That's a possible reason to increase the voltage, though not likely the one the manufacturer considered. Lots of info about when and why and what on my site concerning caps- for some reason I've always been fascinated with 'em.
I may be barking up the wrong tree, but at least I'm barking!
Old 3rd September 2013, 04:00 PM   #24
Sorry to be unclear. By 'larger cap value' in the last post, I was speaking of capacitance rather than voltage.
Old 3rd September 2013, 04:19 PM   #25
cbdb is offline cbdb  Canada
Using higher voltage caps greatly increases the caps lifespan.
Old 7th September 2013, 05:06 PM   #26
ticktock's Avatar
Using long life caps even more does.
thanks
Blaue Leuchtdioden machen blöd. (hb)
sent from NSA monitored device
Power Supply -50V gnd +50V RipX Power Supplies 31 24th June 2013 02:52 PM
DIY 25v power supply cancon Instruments and Amps 3 11th April 2013 10:39 PM
Wanted: 2 x 220uF 25v (or 35v or 50v) Black Gate Standard caps johnm Swap Meet 1 27th September 2012 10:13 PM
50V Power Supply Le Pick Power Supplies 14 10th July 2012 03:42 PM
LT Dual Tracking 3A Regulated Power Supply 1.25V to 20V okapi Power Supplies 56 9th July 2010 02:33 AM
Copyright ©1999-2017 diyAudio
