Weird problem with a preamp with 3 band EQ module - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 9th July 2013, 12:17 PM   #31
csom's Avatar
Originally Posted by Mooly View Post
A lot of these circuits are OK but not perhaps suitable for your needs. The ML3 circuit has balanced inputs for example which you probably don't want. You also probably need a dedicated separate mic preamp as I think I mentioned before. The first opamp stage can easily be changed to normal unbalanced mode and given more gain.
You need to read and study basic opamp theory and then you will understand how the gain and so on is set by the external resistors.
Thank you really so much Mooly!
This is a great help once again!
I had read about op-amps theory ( and used 741 and LM324 earlier) really long ago ( some 20 years ago or more I guess ) But after that I am totally cut off from electronics, math etc. due to a completely different professional life.
So now is the time for me to re-learn everything. And this time I have a great resource person like you beside me. So I feel fortunate and privileged being here
I will make a dedicated microphone circuit and read about the op-amps theory again after I finish the on going LM3886 tri-amping project and ask for help to you again if I get stuck.
Thank you once again.
Warm regards, Som
Old 9th July 2013, 01:31 PM   #32
Mooly's Avatar
You are welcome, good luck
10 Band EQ Fiddlesticks Instruments and Amps 5 28th February 2012 01:18 AM
3 band eq with paramertic kendarmstat Analog Line Level 0 7th June 2011 03:20 AM
mec 3 band eq kendarmstat Instruments and Amps 3 2nd May 2011 01:59 AM
EQ band components ianmgreen Construction Tips 2 23rd April 2011 12:41 PM
3 band eq kendarmstat Analog Line Level 0 3rd April 2011 02:56 PM
Copyright 1999-2017 diyAudio
