John Bowers Active Control Unit preamp: Info sought - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 28th October 2013, 07:49 AM   #21
managed to work it out thanks.
12VDC relay was supposed to be in fact a 6VDC. When one pole was 13.8VDC the other was 7.4VDC. with a diode across the coil cathode end at the 13.VDC terminal, leaving a 6.4VDC difference to power a 6 VDC coil. workaround for the 12VDC relay is to send an earth the 7.4VDC pole and disengage the 7.4 supply by removing a resistor.
One day I will replace the relay with a 6VDC and remove the makeshift earth.
Reason why I was getting low voltages to the op-amps was that the 15AC powerpac it came with had no earth.
Solution: install a 12-0-12 transformer and the other circuits become active!! 12/13 VDC to each of pins 1 and 8 on every opamp
all good!!
Many thanks for taking me back to basics
cheers
Andrew
Old 28th October 2013, 07:52 AM   #22
Mooly's Avatar
Great to hear you figured it out
Its definitely one of those things you need in front of you to visualise what's going on.
Active Tone Control and preamp. Need help urgent! CasperSort Analog Line Level 12 6th July 2012 11:24 PM
My active preamp/tone-control and TL074 kaushama Chip Amps 27 13th June 2011 01:54 PM
John Bowers Active 1 Netlist Solid State 4 11th August 2010 08:37 AM
john bowers active ones dazfj Swap Meet 2 5th June 2009 10:42 AM
John Bowers active 1 speaker prob iorr Solid State 3 30th June 2005 11:11 AM
Copyright ©1999-2017 diyAudio
