Simple analog vu-meter driver ?
Old 30th May 2013, 06:29 PM   #1
00940 is offline 00940  Belgium
00940's Avatar
Question Simple analog vu-meter driver ?
Wrapping up some projects...
I cased an headphones amplifier into an old tape recorder and it has a pair of nice analog VU-meters (Kyoritsu KM-86) on the frontplate. I'd like to use the meters to roughly monitor the output level into sennheiser HD650 (300 ohms). I don't need perfect ballistics. Cheap and easy to breadboard are more important factors here.
Would the following circuit do it ? (it's mostly a simplification of http://www.jlmaudio.com/AT51%20DIY%20VU.pdf ).
Simple analog vu-meter driver ?-vumeter-jpg
R7-R8 are trimmers to adjust the vu-meter (I'm aiming to set the 0VU at a max "reasonable" level for long term listening). The headphones amplifier I'm using won't clip before +/-13V (peak) into 300r, so I need the to pad the signal going into the tl072. 10k in // with a 300r load is ok.
All that is excessive is insignificant. Talleyrand
Old 30th May 2013, 08:03 PM   #2
franzm is offline franzm
Here are some integrated VU-meter drivers K 157 DA 1 ( = 2 Kanal Ansteuer - IC für VU - Meter ) | eBay
Old 30th May 2013, 09:39 PM   #3
00940's Avatar
Thanks, those look like interesting parts but I've got all the parts on hand for the schematic above with the tl072. I'd rather avoid collecting even more parts ;-)
Old 31st May 2013, 09:12 PM   #4
gpapag is online now gpapag  Greece
gpapag's Avatar
Ben
I think you will be OK with you circuit.
If you don’t care about ballistics you can go with something really simple, like the attached, one transistor circuit..
for a better circuit (VU-PPM), you can have a look here
VU And PPM Audio Metering
George
["Second Law is a bitch." - SY]
["I insist on respecting the means of the average person working in their garage/basement." -Scott Wurcer]
Old 31st May 2013, 11:19 PM   #5
00940's Avatar
Thanks George. I'll save this schematic, very simple indeed :-)
I put the first one together this evening. It works quite ok. 100uf is too much in // with the meters I have, it makes it too slow. I'll try 10uf later on.
Btw, I enjoyed some fireworks in the process. Soldered the PS backwards and fed a poor tl072 -20Vdc. It didn't explode but started fuming and slowly split in two right in the middle. Oh happy times.
Old 1st June 2013, 07:37 AM   #6
gpapag's Avatar
Yes. 1uF to 10uF.
When I test new circuits or repair old ones, I wear safety glasses.
George
Old 28th June 2013, 03:19 PM   #7
stoppage is offline stoppage
Sorry could I ask if you're referring to the one-transistor circuit, I've planned to try that out too. Did it originally have a 100uF cap., it's not in the circuit?
Old 28th June 2013, 04:25 PM   #8
00940's Avatar
I was referring to the one in the original post (with the tl072). I finally didn't try for myself the one suggested by gpapag.
Old 28th June 2013, 04:30 PM   #9
Thank you
Old 2nd July 2013, 08:24 PM   #10
Originally Posted by gpapag View Post
Ben
George
Hi ...quick question...is C31 Electrolytic?
Simple analog vu-meter driver ?Hide this!Advertise here!
Analog VU meter driver Vrystaat Solid State 21 17th December 2016 04:04 AM
Circuit for analog VU meter G.L. Tirebiter Chip Amps 10 12th December 2015 07:40 PM
Analog VU-Meter macnomad Solid State 4 25th October 2010 05:30 AM
Adjusting Analog VU Meter DreadPirate Solid State 9 1st May 2006 10:24 PM
t-amp vu meter and volt meter question.... rectaacies Class D 7 3rd February 2006 11:22 AM
