Opamp power bypass
Opamp power bypass
Old 17th May 2013, 07:55 PM   #21
jcx is offline jcx  United States
"motor boating" is specifically low frequency, typcially was on the slope of the DC blocking high pass - there are feedback loop frequency/phase stability requirements at low frequency too - don't close a DC loop around a AC coupled amp
op amp's internal protection circuitry can cause some of them to cycle on/off in thermal limit if loaded too heavily - can will also be at very low low frequency
just possibly high frequency oscillation could cause power dissapation that also cycles the thermal protection
if the circuit allows add a ~100 Ohm R in series with the op amp output, outside of the feedback loop - decouples excessive Cload that may cause oscillation - and can make a easy place to measure short circuit current if there is a problem
I sometimes run bare bus wire or Cu tape on the top side for power, gnd distribution, keeps loop area low - though the bare power traces increase chance shorts with probes, tools while debugging
and a 'scope is a really handy tool when things aren't working - multimeters don't cut it for dynamic errors, oscillation
Old 17th May 2013, 09:06 PM   #22
Navyblue is offline Navyblue  Singapore
Thanks for the advices guys.
I tried 200Ω resistor at the output outside the feedback loop, still no difference.
Could it be that there is something wrong with the power supply? I don't have any 9V batteries on hand though.
And can bad solder job does this?
Old 18th May 2013, 06:17 AM   #23
Mooly's Avatar
Opamp power bypass
Bad soldering covers a lot of possibilities but if everything connects where it should, then however it "looks", well it should still work OK.
Something wrong with the PSU. That's quite possible but its impossible to diagnose from pictures alone.
The best advice I can give is this... the cost of parts is minimal so why not make another board but this time build it up and test it outside of the preamp. I would also use a far far simpler PSU. For an opamp a very simple resistor and zener supply will work well, probably better than all those regs. Much smaller, much easier.
Old 18th May 2013, 05:30 PM   #24
Thanks for your inputs.
I think I know where the problem lies. As you have expected, something on the old PCB is probably turned on. I measured the resistance across the empty fuse holder, it is not infinite (about 100+kΩ), so some current is flowing through who knows what.
Earlier on I tried connecting the output to the power amp without going through the RCA jacks on the PCB. Turned out that is not enough, I also need to disconnect the inputs. Now the noise is much lower, there are still some high frequency whirring if I put my ears to the tweeters, but that is probably my dirty mains. I thought 2 stages of regulation would do it, but I guess LM317/337 were never that great for high frequency noise.
I'd hate to have to remove all the components on the old boards. I think I am going to remove all the active components and see what happens.
Old 18th May 2013, 06:34 PM   #25
Mooly's Avatar
Opamp power bypass
Any noise from a regulator or noise that gets past a regulator is minimal and many orders of magnitude below what would be audible from an opamp. Linear supplies are pretty clean anyway, the only real "noise" is line frequency (mains freq) related and even if there were a couple of volts ripple on the rails the opamp would reject it anyway and not pass it to the output.
Its great that you are working on this and looking for the reason
Old 18th May 2013, 07:46 PM   #26
In the past, I used to have all my audio equipments plugged directly to the mains. If I put my ears to the tweeters, I can hear some kind of whirring noise. Then I started using line filters for my sources (the standard electronic part kind, not the fancy "audiophile" kind). This noise is attenuated significantly. Since then I always plug my sources and line stages behind line filters.
So far everything I built needs this, except a headphone amp with choke filtered PSU. So that was my conclusion. If you look at the LM317 datasheet, the ripple rejection goes down with increasing frequency. Although I agree with you that it would take an awful amount of noise to make it past the opamp. I have no idea though.
I removed the rectifiers and the transistors, that put the resistance across the fuse holder more than what the DMM can measure. But the noise is still there. Then I removed the transistors on the relay circuit and the first stage opamp. The noise is still there.
I still have 2 more opamps and 2 more transistors on board (it's hard desoldering opamps). But it got me thinking, what if I am going down the right path? Is it possible that there is some kind of ground loop through the passive components? I really don't know enough on this. Can I assume that high resistance makes ground loop impossible?
Old 18th May 2013, 10:45 PM   #27
Johno is offline Johno  Australia
Johno's Avatar
Opamp power bypass
Because you get increased noise when you add a bypass cap from pins 4 and 8 to ground it suggests to me that your ground connection is floating or high resistance and that this is feeding noise into the negative feedback divider on the op amp.
I would check continuity of the ground connections from the op amp back through the power supply regs and through to chassis earth.
Old 19th May 2013, 12:25 AM   #28
impuls is offline impuls  Yugoslavia
Sometimes adding block capacitors over existing electrolytes can cause problems if the ground layout wrong connected. Since you use the existing power supply unit I guess you take ground from your device. To repair this problem i suggest that you take only the positive and negative voltage and ground made ​​using two transistors on your new board. New ground connect it with the remains of device.
Sometimes adding one capacitor between positive and negative power supply may help
Old 19th May 2013, 02:55 AM   #29
You guys aren't quite following, but thanks for your input.
- When adding a 4.7uF capacitor over pin 4 and 8, I did not get an increase in noise. It made no difference.
- The increase in noise came from adding a 47nF film cap at pin 4 to ground and pin 8 to ground. I don't know if the capacitor is faulty, it does not happen with 100nF MLCC and 1000uF electrolytic.
- I did not use the existing power supply, only the transformer and its centre tap (ground).
- The problem seems to go away when I don't make signal ground connection through the existing board. My current hypothesis is that AC signal somehow interacts with some of the existing active components, or there is a ground loop (I don't really understand this topic).
Old 19th May 2013, 06:24 AM   #30
Mooly's Avatar
Opamp power bypass
That points to something amiss with the grounds or what you "think" are the grounds.
Without seeing it all in context its impossible to say more. Once you reach a point like this then it needs a scope to help understand what is going wrong.
Without a scope all you can do is rebuild (or at least test) what you have in stages. That means isolating it from the PCB and testing it with battery power as a stand alone preamp. Just isolate the reg outputs and use two 9 volt batteries. Then power it from the tranny. And so on...
Opamp power bypassHide this!Advertise here!
INA217 DRV134 Opamp bypass caps argonrepublic Analog Line Level 0 17th February 2010 03:52 AM
best opamp bypass caps... Htguy Digital Source 1 7th February 2006 01:26 PM
opamp bypass caps with regulated PS Russ White Chip Amps 14 25th May 2005 02:36 PM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
Bypass of the internal opamp of a dac : missed 00940 Digital Source 6 5th July 2004 06:36 PM
