Tone Control - Volatage range for TL072/LF252-N - Page 4 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th May 2013, 11:31 AM   #31
Mooly's Avatar
You have to try a new chip then although its worth checking any feedback components as these set the gain.
Installing and using LTspice IV. From beginner to advanced.
Old 18th May 2013, 01:06 PM   #32
So tell me again, which are the feedback components?
Old 18th May 2013, 01:21 PM   #33
Mooly's Avatar
R1/R2 and C6.
Old 18th May 2013, 01:23 PM   #34
For the first amp its R1, R2 and C6 and for the second amp R3, R4 and C7?
Old 18th May 2013, 05:22 PM   #35
Mooly's Avatar
Yep, but its so simple a circuit that its just to much of a coincidence that all this has happened from experimenting with the preamp. Something has happened somewhere down the line.
Old 27th May 2013, 06:47 AM   #36
Bump!
One of the channels is definately fried. I changed all the feedback components to no avail.
_______________________
Regarding this schematic:
I see that the first op amp is non-inverting and after the tone control stage the op amp is inverting. Do I need to add another inverting op amp to recover the signal?
Old 27th May 2013, 07:33 AM   #37
Mooly's Avatar
If the phase reversal bothers you then all you need do is reconfigure the first opamp as an inverting buffer. Just ground pin 3 and apply the input to pin 2 via the input cap and a series 10K resistor. Then add a new 10K resistor between pin 2 and pin 1.
Old 27th May 2013, 07:42 AM   #38
Is there any audible difference between the two configurations?
Old 27th May 2013, 07:48 AM   #39
Mooly's Avatar
Try it
All you have to do is swap polarity of both your speaker leads. That does exactly the same.
Old 27th May 2013, 07:54 AM   #40
I notice a little bass boost but other than that I can't tell any difference.
You're right Mooly, I fried one channel of the chipamp together with one of the op amps when I was experimenting with it. I replaced them and everything sounds nice now except for a little distortion. I'm planning use the old chip in BTL mode for a sub.
Tone control argonrepublic Solid State 11 13th November 2011 02:32 AM
To tone control or not to... dagerman Tubes / Valves 12 27th June 2011 07:15 AM
Tone control argonrepublic Solid State 0 28th February 2010 01:12 AM
Tone control ckt using TL072 shahraj Multi-Way 2 13th October 2009 05:52 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
Copyright 1999-2017 diyAudio
