Impedance matching pre -> power. - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th May 2013, 12:39 PM   #11
This Forum has many links to external papers.
Just do a search on Jung, Self, Rane, Whitlock and balanced.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 13th May 2013, 12:40 PM   #12
FoMoCo is offline FoMoCo  United States
You could do a quick buffer using a couple of OPA2134s. You might need a couple in parallel, with current sharing resistors. That could drive 600 ohms and can give a 10k input resistance. Barring that... An emitter follower with a 4401 would probably work also.
Account Deletion Requested: 1/26/2014
Old 13th May 2013, 12:40 PM   #13
Originally Posted by borg7x9 View Post
....................get my local tube prof to change the input transformer to something more "Normal" Maybe that's the best way to go.
No.
Check the actual input impedance.
It may not be 600ohm.
regards Andrew T.
Old 13th May 2013, 01:18 PM   #14
godfrey is offline godfrey  South Africa
Originally Posted by AndrewT View Post
No.
I did, It is. From the user manual:
Input impedance: 600 ohm (RCA), 300 ohm (XLR)
Input Power Voltage: 200mV
Output Power: 50W Class A
Output impedance: 4, 8Ω
Frequency Response: 20Hz-20KHz
THD: less than 1.5%
S/N Ratio: 85dB
Old 13th May 2013, 01:20 PM   #15
Zin is not 600ohms. It is 300ohms, if the manual is correct.
regards Andrew T.
Old 13th May 2013, 02:20 PM   #16
DF96 is offline DF96  England
It is conceivable that there is a similar confusion for inputs as there is for outputs, so 'input impedance' might actually (wrongly) be 'optimum source impedance'.
This problem arises because when lines are long compared to wavelengths (RF and long line audio) you need impedance matching at both ends, and are happy with the corresponding -6dB loss. Unthinking people then carry over the idea of matching into short audio connections, where a match is usually the last thing you need. Or 'impedance match' gets re-used to label not matching but using appropriate impedances - which then confuses people.
Old 13th May 2013, 04:01 PM   #17
The input might be specified as 600ohms compatible.............
Zin....is 300ohms, if the manual is correct.
Originally Posted by DF96 View Post
It is conceivable that there is a similar confusion for inputs as there is for outputs, so 'input impedance' might actually (wrongly) be 'optimum source impedance'.............
Yes Mooly,
I still think the manual is wrong.
It is more likely to be stating the required source impedance rather than the actual input impedance.
The actual input impedance needs to be checked before any decisions are made about purchases or modifications.
regards Andrew T.
Old 13th May 2013, 04:28 PM   #18
just found this link for Whitlock + balanced.
Ballanced Unballanced what does it mean??
But self + balanced does not work.
It returns the message that self is too common and has been omitted from the search string and search only returns the >37000 results for balanced.
regards Andrew T.
Old 13th May 2013, 10:46 PM   #19
Pano is offline Pano  United States
Pano's Avatar
That make sense to me. Why would you want an RCA in with a 600 ohm impedance.
With the right tools, the input impedance could actually be measured. With a couple of resistors and some clip leads, it could be estimated.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 14th May 2013, 02:17 AM   #20
borg7x9 is offline borg7x9  New Zealand
Pano, would you like to see the circuit diagram of the power amp ??
Impedance matching for DI to Mic Pre Fezzle Instruments and Amps 67 27th February 2012 09:32 PM
Impedance matching for DI to Mic Pre Fezzle Solid State 1 10th February 2012 06:13 PM
MiniDSP -> Passive preamp/potentiometer. Impedance matching? lofgrenmeister Digital Line Level 15 26th August 2011 03:04 PM
Impedance matching; phono > pot > A/D convertor? Aleksunder Analog Line Level 4 25th July 2007 06:29 PM
Matching BOSOZ > SOZ impedance Roberto Amato Pass Labs 2 30th August 2002 10:14 PM
Copyright 1999-2017 diyAudio
