Phaseca--My new diy pre amp - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th May 2013, 02:03 PM   #11
kawo is offline kawo  China
Yes^^ Design their own pre-amp
Old 30th May 2013, 02:28 PM   #12
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
The picture is petty small, there.
Also, it appears to have virtually the same amplification section rubber-stamped across the design. Also, it appears that the single input becomes a pair of outputs ... which from looking at the design (at low resolution) also appears to NOT be symmetric in phase, so... what's the main point ... to have TWO independent outputs?
I apologize if Mr. James Pang is a wickedly cool friend or something. But boy... this just seems to be obtuse (over-engineered) in using way more parts than necessary. FOR a preamplifier!!!
GoatGuy
{edit} PS: was there any statement of theory as to why this particular kit was to have solved all the world's problems and made the heavens sing the praises of the analog phonograph needle? I recommend three things: [1] please get a larger picture posted of the schematic. [2] If there are supporting "theory" (or "design goals") docs, please post. And #3 ... are you having fun? ... because that - in audio DIY - is almost 75% of "the point".
PS: is there a special case for the thing?
Thanks... GoatGuy
Old 1st July 2013, 06:05 PM   #13
Complete
Help with DIY Sub Pre-Amp crazifunguy Chip Amps 23 7th December 2012 08:57 PM
pre amp suggestions, DIY or Non DIY, Im easy mondogenerator Analog Line Level 5 20th August 2012 05:11 AM
Any information and schematic about diy Pass Lab XA 200 power amp and X 0.2 pre amp? jelou Pass Labs 17 4th December 2011 10:56 PM
diy microphone pre-amp sadim1223 Parts 11 13th March 2009 04:30 PM
help troubleshooting this diy pre-amp zobsky Tubes / Valves 21 2nd November 2003 11:06 PM
Copyright 1999-2017 diyAudio
