Help! Kenwood Basic C-2 left channel out (phono only)
Old 2nd May 2013, 03:45 AM   #1
Futureman is offline Futureman  United States
Default Help! Kenwood Basic C-2 left channel out (phono only)
I just acquired this unit and it sounds great in all modes *except* phono, where the left channel is fuzzy and barely audible. Music plays just fine through my Onkyo, and switching TT interconnects going into the preamp results in no change. I've also de-oxited the heck out of the pots and switches.
Any ideas?
Old 2nd May 2013, 07:52 PM   #2
Mooly's Avatar
I would look for "obvious" issues first before going to deep. Something like this could even be physical such as cracked print around a socket or selector switch.
The correct way to fault find this is simply inject a tiny signal into the left phone input and trace it through using a scope. Its literally two minutes of a job that way.
No scope ?
The circuit is a not quite so simple opamp based phono stage using a pair of FET's and transistors "in front" of the opamp.
First step without a scope is to check the DC conditions around the opamp but I suspect the problem is elsewhere tbh
You could link the left and right feeds and see if the problem is in the front end. Just isolate C11 and connect feed to C12 (the right channel opamp output)
Old 2nd May 2013, 08:43 PM   #3
Thanks Mooly! The Kenny is in the hands of a tech as I type. No bench fee!
Help! Kenwood Basic C-2 left channel out (phono only)Hide this!Advertise here!
Kenwood Basic M1 Amplifier Rte 66 Dave Solid State 23 24th October 2016 11:45 AM
Can I have the sub woofer channel and the left and right channel as one? Boscoe Chip Amps 7 21st February 2010 06:56 PM
Kenwood basic C2 - channel out bilbospil Solid State 2 24th January 2010 12:49 AM
Dead Left Channel on my Kenwood CI Pre-amp bulgin Analog Line Level 0 22nd September 2009 02:33 AM
Kenwood basic m2 Johnny25 Class D 0 20th January 2006 07:48 PM
